From my research and what everyone tells me the gas tank in any vehicle should be under constant vacuum. This week after my car had some issues, well i started to notice that the gas tank was under pressure, so much so that it was spewing out fuel where the fuel pump bolts into the tank. i had a new o-ring gasket and even put rtv silicon gasket on it. It somehow still sends gas out which is by no means normal. I could see it leaking out after i fill it up but right now its 1/4 full.
Vacuum dropped by 4 psi at idle which makes me belief there is something causing it to happen.
Anyone have any ideas???
Edit: this is on a sr20det powered 240sx.
