Im planning on dropping in a set of Infinity 5000CS 5 1/4 speakers...
http://www.sjgreatdeals.com/tb-5000cs.html
Which will be powered by a
http://www.cardomain.com/item/INFREF7520A
Does this look like a decent setup?
Thanks.
Thanks.
The amp is okay, but those speakers aren't anything special. I went from some old pioneers to these and didn't notice anything different. The Kappas are the ones you want.
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
yea definatly get the kappa's. but be warned all infiniti speakers dont have much midbass. so you better have a woofer or somethin. the amp will match the speakers fine.
Submaker.Illest.
Would you suggest these guys?
And is it a pretty good price?
Thanks for the advice.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA%3AIT&rd=1
Those look better, but make sure they aren't reconditioned or anything.
Also, keep in mind that infinity's lack any bass whatsoever, so don't expect too much. I've used both references and kappas, both amped, and they dont put out too much.
Alright, that should be a change for me then... im used to using the stock speakers in a 2001 civic... and man, THOSE PUT OUT BASS!!!! Yes, i have 2 rear 6x9's, hopefully that should hold me on bass, until i can afford an amp/sub.
Hey nate...wherea bouts are you?
I have a set of those infinitys installed..just off a deck...
you can come take a listen if you'd like
