Product # 4375
Size: 2 1/16" (52.4mm)
Are you looking for a gauge that will monitor your engines air fuel ratio? Look no further. The Auto Meter Air-Fuel Ratio Monitor is the answer. This gauge is a full sweep green to red LED, lean to rich display that is easy to see day or night. It monitors exhaust temperatures thru your factory oxygen sensor. With this Air Fuel Ratio Gauge, you can prevent exhaust temperatures from getting too hot.
Works with OEM and aftermarket oxygen sensors. Installs without special tool requirements.
Notes:
Will work with most factory narrow-band O2 sensors. May require model 2244 in the Accessories Section.
LED digital display.
Will not work with Wide Band O2 sensors, please check your application.
BRAND NEW in box
70 bux takes it
