VTEC discussion (from iVTEC sticker thread) - Beyond.ca - Car Forums
Results 1 to 20 of 26
Thread: VTEC discussion (from iVTEC sticker thread)
    Sep 2002
    CSpot
    11 sec weather van
    If vtec is so great, why do the higher HP hondas delete it? From my understanding (not from a great source) vtec is variable valve timing- it switches from one set of cam lobes to the another at a specific RPM(4000??). Is the intake runner length changed as well like on the yamaha SHO enigne?
    Ford tuning guy...
    I have too much respect for the idea of God to make it responsible for such an absurd world.
    Georges Duhamel
    joke of the day:
    Originally posted by Danger_Mouse
    There is a replacement for displacement. It's called technology.
    Jul 2002
    '15 GTI
    umm both the NSX and S2000 have vtec...
    that doesn't typically happen until your pushing a lot of hp. There's no magic number, but I'm guessing at around 400hp+
    I believe the reason for this is because when your making so much power there is no need for the crossover (like it makes no difference), so that is why people "delete" it.
    Sep 2002
    CSpot
    11 sec weather van
    I meant serious power, not out of the box stuff.
    Thanks buh_buh
    Ford tuning guy...
    Georges Duhamel
    joke of the day:
    oreo cookie
    a wrx.
    refer to my vtec bible: http://forums.beyond.ca/showthread.p...threadid=5372&
    and vtec has nothing to do with intake runners, although the integra gsr did have secondary intake runners that opened up at some rpm via butterfly valves. none other hondas come to mind that have variable intake runners
    Sep 2002
    CSpot
    11 sec weather van
    Originally posted by Jeff TYPE R
    refer to my vtec bible: http://forums.beyond.ca/showthread.p...adid=5372&
    With ivtec, how is the valve timing, lift, and or duration changed? Since cam profiles are fixed(machined) how are valve events changed? The only thing i can think of is no camshaft, and the valve are controlled through an electric solenoid. Saw that once as a prototype on a ford V8.
    32 valve cobra engines(96-8) have a secondary rpm controlled runners(IMRC) like you had mentioned on the GSR.. The were dropped in 99 for a much improved tumble (single)port.
    Sorry for the thread hijack....
    Ford tuning guy...
    Georges Duhamel
    joke of the day:
    hijack fixed!
    Medicine Hat
    2004 Toyota 4Runner V8 Sport
    ivtec, is some what similiar to normal vtec motors.
    At a predetermined rpm a solenoids slams pins in to the rocker arms joing the arms together forceing them to ride on the high lobe of the camshaft.
    However in ivtec the computer senses when you need this, by your driving style, load on motor and so on. Then it triggers the solenoid. Not always on a certain rpm, like the original vtec motors.
    2004 Toyota 4 Runner V8 Sport
    2001 Prelude SE- Sold
    Speed Kills...Drive a Ford...Live Forever!!!
    oreo cookie
    a wrx.
    mostly wrong.
    ivtec is just hondas name for the same old vtec system PLUS camshaft phasing. so:
    vtec: 2 distinct cam lobes
    ivtec: 2 distinct cam lobes AND camshaft phasing (which honda calls VTC)
    the camshaft phasing (VTC) is really good cuz it retards the cam timing by something stupid like 50 degrees at idle and advances it hardcore when it needs to. its continuously variable and is controlled based things like rpm, throttle, speed, load, etc..
    oreo cookie
    a wrx.
    the camshaft itself is basically wiggled around
    Sep 2002
    CSpot
    11 sec weather van
    Meaning point of which valves close and open is changed in relation to crankshaft degrees?- Meaning intake and exhaust centreline? Do you have any pics? I am having a hard time picturing this, as from what i gathered, the cam is still driven and indexed by the crankshaft(driven by a belt).
    Ford tuning guy...
    Georges Duhamel
    joke of the day:
    oreo cookie
    a wrx.
    yea, im not actually sure how honda manages to adjust the camshaft phasing...but a lot of manufacturers are doing this nowadays...
    hmmm ive found this, but it doesnt really explain too much:
    edit: who cares, lets just say its magical and call it a day
    Dec 2002
    Edmonton, AB
    Dakota ... what? Yes, I know its a truck.
    On variable valve timing:
    The camshaft phasing or variable valve timing or whatever manufacturer A and B call it is done by controlling the oil pressure in the 'phaser' (like a cam cog) ... basically the belt drives the cam cog or phaser, but the outside can rotate relative to the inside .. its like two concentric pipes. By increasing the oilpressure (based on RPM, throttle position etc) it will rotate the inside part (which is directly attached to the cam) relative to the outside part (which is directly attached to the timing belt/chain). I wish Jeff's picture showed up as more than a red X, then I might be able to explain it better.
    to answer your first question 347, there are two distinct profiles cut on to VTEC cams ... the VTEC basically switches the valve following from one set of lobes to the other at a certain RPM (its like having a torquey camshaft at low RPMS that you can magically switch out to a high RPM camshaft at a given RPM)
    "Nobody snuggles with Max Power ... you strap yourself in and feel the G's" - Max Power
    Sep 2002
    CSpot
    11 sec weather van
    Makes sense- Thanks!
    Ford tuning guy...
    Georges Duhamel
    joke of the day:
    oreo cookie
    a wrx.
    thats what my nonworking picture showed haha
    Dec 2002
    Edmonton, AB
    ya, there ya go .. its working now.
    off topic: hey Jeff Type R, were you pulled over on whitemud and 91st at about 11:15am Saturday? I thought I saw red/orange/whatever corolla and some oriental dude that looked like he was cursing at the car or something. was that you? ha ha
    E36 4dr
    If Vtec is designed for a NA application, theoretically wouldn't the system benefit from custom ground turbo cams for vtec application? From the limited number of examples i've seen, people usually "delete" vtec application when they run a bolt on turbo kit with stock valve train.
    oreo cookie
    a wrx.
    hmm nope not me...i was still asleep at 11 in the morning on sat!
    Dec 2002
    Edmonton, AB
    my guess here (and its just a guess) is that the VTEC system isn't as durable under boost ... i.e. it'd be tough not only for that little pin that slams into the secondary rocker arm to get into place, but it'd also be tough for it not to shear while opening the valves under boost load. Particularly the exhaust would be susceptible to failure I think because it has to open against the force of the cylinder pressure (but most VTECs are only on the intake).
    That's my guess is its just a durability issue (go ahead ppl ... flame on with how honda is second to none for durability and VTEC rules the world and blah blah blah if you don't want to believe me)
    A turbo'd vehicle would undoubtably benifit from some kinda variable valve system though ... there's no reason it shouldn't. Subaru put VVT on the STi ... I'm sure there's some other high end cars with VVT or VVLift that are boosted.
    I'm still waiting for solinoid actuated valves to come out ... it'd completely eliminate VTEC and any VVT systems out there .. .not to mention own them all. That's a whole other issue though.
    oreo cookie
    a wrx.
    actually, the reason ppl remove vtec under high boost applications is because the aggressive lobe is TOO aggresive...theres so much overlap that the boost basically forces the uncombusted mixture out the exhaust valves before the exhaust valves have a chance to close.
  1. MX-3 Discussion
    By shay in forum General Car/Bike Talk
    Latest Threads: 02-15-2003, 12:24 AM
  2. proof a type r sticker makes you faster
    By finboy in forum General
    Latest Threads: 11-20-2002, 01:14 AM
  3. Sticker group purchase
    By Mortimer Schnur in forum General
    Latest Threads: 07-08-2002, 09:59 PM
