Heat cycling Tires - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Heat cycling Tires
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    Default Heat cycling Tires
    do you need an over for this or can it be done with them on your car? I hear it helps improve the wear and stickyness of your tire?
    Oct 2002
    Lurking in some bushes outside your house
    S14/D21
    Yes you can do this with the tires on the car. Wont make a difference unless its an R compound tire.
    Oct 2002
    care to post how, and yes im aware that it is only for R compounds... im looking to get a little better everything from my next set of tires
    oreo cookie
    a wrx.
    Highway drive them an hour each direction (as in, rotate the tires to the other side of the car) and then lay them flat for a day.
    I'm sure the tire manufacturer has more specific directions if you want to be precise with temperatures and whatnot..
    Jul 2005
    lethbridge
    gixxer 750
    Original Post Removed. (Please read the Forum Rules and Terms of Use before posting again, or risk getting banned).
    Oct 2002
    S14/D21
    Taken from Kumho's site.
    "Heat cycling helps you get the most consistent performance and tread life out of your tires. It is the process of gently bringing the tires up to temperature for a short duration and letting them cool. Ideally, you should break in your tires, remove them from your vehicle, and set them aside for more than 24 hours before your track sessions and races"
    Tire Rack
    "The first time a competition tire is used is the most important. During that run, its tread compound is stretched, some of the weaker bonds between the rubber molecules will be broken (which generates some of the heat). If the tires are initially run too hard or too long, some of the stronger bonds will also be broken which will reduces the tire's grip and wear qualities. Running new tires through an easy heat cycle first, and allowing them to relax allows the rubber bonds to relink in a more uniform manner than they were originally manufactured. It actually makes them more consistent in strength and more resistant to losing their strength the next time they are used. An important heat cycling step is that after being brought up to temperature, the tires require a minimum of 24 to 48 hours to relax and reform the bonds between their rubber molecules."
    Basically what i was gonna say. Find the specs for proper temp. Drive on em, get them up to temp. An infared thermometer makes this easier. Remove and let them cool.
    Apr 2004
  1. heat filter
    By Moe Man in forum Mechanical
    Latest Threads: 10-20-2003, 07:57 PM
  2. Latino Heat 2
    By civicsi in forum Street Encounters
    Latest Threads: 08-27-2003, 11:38 PM
  3. Heat Wrap
    By The EquAzn in forum Performance Modifications
    Latest Threads: 06-14-2003, 01:09 PM
  4. heat shields
    By krazykokonutz in forum Mechanical
    Latest Threads: 04-14-2003, 06:24 PM
  5. Hehe, remember the Latino Heat civic?
    By van in forum General
    Latest Threads: 09-17-2002, 07:59 AM
