I'm trying to figure out a way to (a) jack-up the stairs which have "sunken" about 2" from their original position and (b) to secure the flight of stairs to the joist/floor head-out so that this doesn't happen again.
This was an early 90's Shane Home show home, so I'm surprised there wasn't more care in making sure things were done correctly.
From the pictures and what I can see, the entire stairs are being attached to the floor head-out with only a few nails, which were nailed through the top riser butting up against the head-out along with some diagonal nails which have loosened overtime between the top of the stringers on the L&R to the floor/nose of the main floor.
You can see some nails backing out of the riser, and the gap of where the carpet used to attach to the riser, and the main floor nose is visible as to how much movement there's been over the 30 years.
My thoughts are to add some horizontal 2x4's under the stairs so that I have a place to use the jack-up posts to "jack-up" the stairs again with an even force. At which time, I will have some verticle 2x6's run from top of the back of the strings down to the ground creating "feet".
Another idea I had was to find some really long-ass lag bolts and just drill through the top riser into the floor head-out to fasten the stairs. This I think would be temporary, as once it sees a vertical load again, will start "ovalling" the holes where the lag bolts are used.
Any ideas on how to fix them would be welcome! Has anyone had this happen to them?
No Header Board for the stairs to attach to the floor head-out
Gap between the backside of the top riser to the floor head-out (~1/2" or a bit over 1cm)
