Haltech and other standalone questions (Maxt?) - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Haltech and other standalone questions (Maxt?)
    Default Haltech and other standalone questions (Maxt?)
    I'm shopping for a standalone setup for someone. Looking at the Haltech EK6, and it states that there's only 32 points for fuel for each MAP point.
    Maxt, you've used this, can you explain how this works? 32 seems to be a little low on the resolution side to provide a smooth A/F.
    Currently looking at SDS, Haltech EK6, and DTAfast E48. DTAfast looks to be a winner, but it's more designed for a 4 cylinder application, so 6 cylinder operation may suffer. Price wise, SDS is the most expensive, but it doesn't need a laptop (the guy's going to need to buy a laptop with the other 2 systems).
    The engine in quesiton is a 3.2L 6 cylinder Supercharged with VTEC.
    a van down by the river
    Bmw and ford
    Look at Autotronic, There is a couple really knowledgable people on honda-tech that love this standalone.
    You got a website for them? I can't seem to find it anywhere (google's slackin' today).
    Edit : It's Autronic... taking a peek now.
    ecstasy_civic's Avatar
    ecstasy_civic is offline MMA guru, but still rage2's bitch
    Aug 2002
    08 Si
    what about chrisng's wolf 3d?? would that be any help at all? or not up to what your looking for?
    Know about Wolf3D, staying away from Wolf3D. Just took a peek at Autronic, damn cool, but pricey .
    Aug 2002
    08 Si
    ok, just an idea. good for rx7's
    Bmw and ford
    Check these guys are for pricing
    http://www.dynospeed.com/
    Ben is the guy you want to talk to.
    On a site note, rage2, This Ben guy has done some tuning seminars around the US. Not specific to any system, imports etc..., but goes though the basic of how to tune a car. Do you think that we could round up 10 -20 people @ $500 / person and try to get this guy up here.
    $500/person? Doubt it. I'll hold a seminar for $500 a person and pass on my tuning skills .
    It's really not that tough IMO. 90% of tuning secrets are available on public forums (you just have to weed through the facts from the fiction).
    962 kid Guest
    Tuner1's Avatar
    Tuner1 is offline Tunerworks Guru (E36S50B32)
    Jul 2002
    ///MPower, 4x4, Bianchi & Trek
    Default Re: Haltech and other standalone questions (Maxt?)
    VTEC and VANOS are very different systems. VTEC is bascially an on/off switch, VANOS is not. This may complicate matters with a standalone? I say burn the car and buy an SL55
    07 Mazdaspeed 6, 89 Mustang LX
    Default Re: Re: Haltech and other standalone questions (Maxt?)
    Yeah, but thats your solution to everything
    AFAIK, the VANOS system in question is on/off, not fully variable, but I was told it MAY be off at low revs, on at mid revs, off at high revs. I know the newer VANOS systems are not on off. So a standalone with multiple triggers is needed.
    Originally posted by m10-power
    Early VANOS are run off a relay (on/off) but the position allows oil pressure to move the camshaft retard or advanced depending on relay position, the oil pressure increases as rpms rise so the controls actual advance. This is a simplified description. Forced induction doesnt like overlap so one would want to re-locate the advance stop to restrict the camshaft movement. Not that this has anything to do with your vtec...
    Yep... pretty close. Here's a URL with a description :
    http://www.bmwworld.com/technology/vanos.htm
    I don't think it changes based on oil pressure though, just 2 stage. It's off at idle, on right off idle, and at 5000rpm it's off again. Should be fairly simple to map that with a dual trigger setup (as long as there's 2 rpm triggered outputs available). Simple XOR gate will handle it .
    Double VANOS on the other hand, is a much more complex monster.
    Jul 2002
    944 535xi F250
    Vanos is either on or off, the oil pressure has no effect on position. The overlap in either position occurs below 1mm of valve lift so there is very little flow.
    Engines with infinitely adjustable valve timing use a oil pressure modulation valve to vary the oil pressure acting on the advance/retard position.
    Sep 2002
    BoostLand
    something green
    I completly missed thjs thread, don't go to this area much..
    The haltech system, is a pretty good system.. The 32 points per map is better than most systems, and its quite smooth in 500 rpm load points..I have a wideband and I can keep the car within .1 of a given air fuel setting through out the rev range on boost..
    Yes it has v-tech control..
    I prefer the laptop, you don't have to be a nintendo pirate to navigate your way through menu's, I was never very good at video games, thus I absolutely hate the hand controller type system... plus looking at the adjustments on a hand controller limits what you can see at one time, some of the hand controller systems now are laptop capable, but then you may as well get the better system and save the cash and get the laptop system in the first place.. lap tops can be had for 50.00.. and when it comes to EMS software the older the laptop the better..
    The haltech displays all the engine data on the bottom of the page while you are in any of the map and data screens, a nice touch and yes it has V-tec control (e6K)..
    THe E-11 looks to be totally over the top.
    The beauty part of the haltech is that works with most factory ignitions, alot of other systems, seperate or certain pickups/ignitors/coils must be used, its also hi and lo injector impedence friendly..
    Yes the SDS seems to need a price correction, its way to much money when you compare it other systems..Maxt
    Too loud for Aspen
    Apr 2003
    Red Deer, Alberta
    Really FAST Ones
    It is not a true standalone but I love the new E-manage the dealer software allows me to run additional injector maps complete injector control as well as timing without having to adjust or even mess with the airflow tables (unless you want to) I prefer not to as this can mess up lots of other areas dealing with load. Optional speed density control system as well as complete timing control accuracy to .1 of a degree. Voltage clamping is also avail to get by those nasty fuel cuts. Not true standalone but the price is right and the control is awesome for a piggy back system. Probally get into a complete system with the optional sensors for under a grand. Oh yea 16*16 maps. What I like about the piggy backs is the rest of the ecu controls ie) antilocks brakes and the like all stay in stock format. I am probally going to get flamed for this but oh well I think for the dollar it is a great system. Haltec nice just pricey thas all.
    Lookin Good is Goin FAST
    "HOME of the AWD DYNO"
    Oct 2002
    22 ZR2, 06 YZ250, 77 KZ1000 supercharged
    Rage the program is dos based, I like the nintendo argument, and yes SDS is overpriced and "older technology" IMO.
    I agree emange is a nice little setup. It has v-tec map options too. That's what I would go with, do honda's have a knock sensor, im guessing no.
    Bmw and ford
    Originally posted by Hollywood
    I, do honda's have a knock sensor, im guessing no.
    b series engines have knock sensors
    Apr 2003
    Red Deer, Alberta
    Really FAST Ones
    Hey Rage if you wanna check it out and see the full tunabilty of it PM me I will set something up. I have several cars coming up some weird aps. Just let me know and come for a drive. Yes the emanage has vtec setup also.
    Sep 2002
    Calgary, Alberta, Canada
    I like the eManage as well, I almost went with it in fact. I like the fact Greddy is making other products like the Profec E01 boost controller to operate with the eManage. I didnt like the fact it was so "piggy back" based. It depends on what car it's to be used on but on older cars with older ECU's, older style mass air flow sensors, old wiring etc, I thought it would be better to go with a true stand alone. I'm not sure if it fits your application Rage but check out www.microtechefi.com it's what I went with, it's not as affordable as it once was because the Australian dollar gained some value but it's still a good unit.
  1. Good Affordable Alarm and Starter...(other than compustar)
    By Impreza in forum In Car Entertainment / Electronics
    Latest Threads: 11-25-2003, 03:29 AM
  2. standalone EMS for RX-7's
    By REFLUX in forum Performance Modifications
    Latest Threads: 06-25-2003, 10:33 PM
  3. FS: F-MAX Turbo Kit & AEM Standalone EMS for 97 and up Preludes
    By choweyt3t4 in forum Automotive Parts
    Latest Threads: 05-21-2003, 10:33 AM
  4. FS: Wolf3D Ver 3.1 Standalone EMS
    By Chris Ng in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-08-2003, 04:24 AM
  5. Replies: 12
    Latest Threads: 06-20-2002, 01:58 PM
