Busting a nut: members blow their own horn on the least messiest way to get it off - Beyond.ca - Car Forums
Results 1 to 20 of 39
Thread: Busting a nut: members blow their own horn on the least messiest way to get it off
    2020 Subaru Forester Sport
    Default Busting a nut: members blow their own horn on the least messiest way to get it off
    Bought this from Canadian Tire yesterday, will make swapping tires much easier
    Careful with that thing. It does 240ft-lbs, that's like 3x more than some smaller cars require. I have one and I don't know if I will ever use mine again. I have been using mine for 5 years or so happily, until last year when I went to remove the rear tire on my wife's car. Undoing the bolts...i snapped 4 out of 5 of them! They were rusted and I should have sprayed them with WD40, but needless to say, replacing 4 bolts on a Sunday afternoon was not very fun, luckily Canadian tire was still open and had the bolts I need and I was able to slide them in without disassembling the hub.
    Since them....I just use my manual torque wrench.
    I didn't even hold it there for a long time or anything, i normally do a quick two clucks and move on to the next, but must have stressed the bolts over time and it finally snapped.
    Oct 2009
    rally pig
    thanks for the heads up, yeah i will be using primarily to speed up putting/removing the bolts, will be using a manual torque wrench for the initial/final lock.
    Always break rhe nuts free with a breaker bar.
    Only 15min from Aspen!
    Nothing interesting anymore
    Instructions unclear. Now I have a breaker bar in my underwear. How should I proceed?
    With caution and enthusiasm
    Wait - who the FUCK installs and tightens lug nuts with an impact gun?!¿!!?¡? That's some fuckin FULL RETARD kind of shit. Like, Wal-Mart Tire & Lube kind of shit.
    Remove = impact.
    Install = start threads by hand and then MAYBE gain a few turns with impact
    Torque = Torque. Mother. Fucking. Wrench. Period.
    Is this a car forum?
    Grimace
    Last year costco broke one of my wheel studs off and said something like, you should talk to whoever put your wheels on last. It was me. By hand.....
    Can't you tighten them (finish with wrench) with those torque sticks though?
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    I had that Canadian Tire impact a long time ago and found it quite useless. I use a Milwaukee M18 Fuel 1/2" that removes the nuts pretty quickly. It's overkill for tire removal but it does the job really well. I have never broken a nut or bolt with it, but some of the cheaper bolts can be a bit soft.
    Never use your torque wrench to remove nuts. Use a breaker bar but make sure you slide your penis out of the way first.
    Apr 2004
    What's wrong with removing them using an impact gun? I've been using an impact gun to remove for about 5 years now (3 vehicles, twice a year) and never had a problem. Is it because there would be more chance of issues if bolts are seized?
    From Earlier in this same thread:
    I'm reading this as "I shouldn't have used the impact gun to INSTALL my bolts because it over-tightened them and stressed them out so that a future removal snapped them off."
    I think Sabad (and probably me) are saying "either impact gun or giant, sniped breaker bar will still snap your bolts during removal if someone did them up to over triple what they should've been tightened to."
    Agree?
    Dec 2005
    not calgary
    changes every year
    Agree?
    Have you ever broken a stud with your human torque strength?
    Stampede Central
    is pretty sharp lookin'
    Quote Originally Posted by 03ozwhip View Post
    My dad used to use a 2ft long bar and step on it (full body weight) to "make sure the studs were on tight"
    One year he snapped 2 of them before his mechanic told him to stop that
    math: 170lb man x 2ft = 340ft-lb
    Agree?
    Could be right.
    Aug 2002
    992 T-hawk Golf R
    Yes. I snapped one off that was galled on my STI.
    And I agree with some of the others, if a stud is galled or breaks at the time of removal it was already NFG. I don't see any issue using an impact gun to remove lug nuts, I also don't see any issue using a torque stick and impact gun to tighten them but I could be wrong.
    Personally, I crack everything loose with a breaker bar simply because my compressor and impact gun aren't powerful enough.
    I like neat cars.
    Stampede Central
    whoever named this thread...
    Realy missed opportunity. Should have been "how to bust a nut".
    ^ hahaha, so true , bunch of nut jobs
    to sum up:
    - impact deez nuts off
    - use a breaker bar (with 'calibrated' eblow torque, oops i mean elbow) or torque wrench to install
    Dec 2005
    not calgary
    changes every year
    During removal is what I meant...over torquing can definitely happen while tightening, but I've never heard of breaking while using a breaker bar to loosen them.
    Mar 2005
    POS
    I think most people think 100ft lbs is a lot of torque and it’s tires so they go overkill cause nobody wants a tire falling off while driving. I have a 18” breaker bar and torque wrench and it doesn’t take much effort to put on or take off if torqued correctly.
  1. Replies: 17
    Latest Threads: 07-29-2015, 03:37 PM
  2. Replies: 25
    Latest Threads: 08-31-2011, 11:38 AM
  3. Replies: 18
    Latest Threads: 02-23-2011, 10:44 AM
  4. FS: J's racing, T1R Nut, Random Nut for Honda and Toyota
    By snow_daniel in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 02-07-2011, 01:52 PM
  5. WTB: integra horn and horn harness
    By Rufus`` in forum Automotive Parts
    Latest Threads: 04-20-2005, 06:43 PM
