Jiffy Lube Creekside - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 38 of 38
Thread: Jiffy Lube Creekside
  1. #21
    Dec 2006
    Lease
    Quote Originally Posted by G-ZUS View Post
    Isnt this place owned by a beyonder
    I doubt he's the one that dealt with the plug though. Find the tech's dad
  2. #22
    Sep 2006
    Secret City, Alberta
    2018 Civic Si coupe
    Yeah, this specific location is a beyonder owned one.
    It's in the parking lot of his Chinese restaurant. Oil is oil.
  3. #23
    Affordable Condo
    Acura Lexus
    Quote Originally Posted by Sugarphreak View Post
    Porsche quoted me 655$ for an oil change recently... I feel like that is a semi-strong reason, haha
    Also dealerships are hit and miss anyway.
    There is a Jiffy Lube near me and the guys that work there are like oil guru's... I've never met workers that knew so much about oil as the people at this place
    Welcome to p car club
    Just pay the bill lol
    Originally posted by rage2
    I am user #49
  4. #24
    V8s
    There isn't any real evidence that shows that the dealership tech is somehow better than a Jiffy Lube tech
    I've had such bad experiences with tech's at dealerships, my faith is low
    Independent would be better I think, might try that
    Yeah dealerships are rarely the right answer as well haha. Good Indy is almost always the right answer.
  5. #25
    Jun 2020
    Airdrie
    Do we have a thread on best indie shops?
    I found one recently...Chanda Auto by Chinook Mall.
  6. #26
    Aug 2006
    calgary/AB
    95B
    I am assuming that is for the First Macan GTS service? or Just for a Oil change?
    I did the first service on mine couple of weeks ago and it was $ 425.
    Maybe yours is Price adjusted for Vancouver
    Back to the Jiffy Lube on Creek Side , when I had the winter beater I have taken mine there for Oil changes there and I had no issues.
    They were nice to deal with IMO
  7. #27
    Apr 2003
    F10M/F87/NA2/W220/V90/E46ZHP/SE3P/DC2
    LOL indy hires the same noob tech to do your oil changes...
  8. #28
    V8s
    Quote Originally Posted by Team_Mclaren View Post
    I think the differentiator is the indy has the most to lose if they do a bad job. Dealers and jiffy lubes will always be lined up with customers who don't know/care about their cars, are just there for warranty work, etc.
    An indy has to rely much more on reputation and good CX for future work than either of the other two, and therefore is more likely to deliver work they can stand behind or remediate mistakes made by the noob instead of telling the customer to kick rocks.
  9. #29
    Nov 2021
    E46
    Quote Originally Posted by R!zz0 View Post
    I went to Jiffy Lube on Creekside on Jan 29th, 2024, and they did do an oil change and checked my air filter and topped off my coolant because it was low according to their tech. Next day I'm driving my son to his soccer practice in Bearspaw and I notice that my check engine light is on. Once we get to Bearspaw Lifestyle Centre, I opened my hood and saw that my air intake tube was completely disconnected from the air filter box. I didn't have any tools with me so I pushed it in as much as I could. The check engine light remained on and when i got home, i tightened the clamp on the air intake tube. I even disconnected the negative battery cable to turn off the check engine light. Next day i was dropping my kids to school and the check engine light came on again. I took my van back to Jiffy Lube and they tightened the air intake tube (according to their tech it was loose) They got their Innova scanner and turned off the check engine light and said, "come back if you see the check engine light on again"
    In the afternoon while on the road picking up my kids from school, the light comes back on. I took the van again at Jiffy Lube and they again turned off the light with their scanner. This morning (Feb 2, 2024) on the road dropping my kids off at school, the engine light comes on again. Took it back to Jiffy Lube and their supervisor tells me that that the code is P0330 which is a knock sensor 2 circuit (bank 2)
    He called his manager and told him about the issue and his manager told him to tell me that bank 2 is at the bottom of the air filter box and Jiffy Lube has nothing to do with that. Before I took my van to Jiffy Lube, I had no check engine light on.
    It could be a coincidence that you now have this fault, but it also might not. P0330 doesn't mean you need a knock sensor, it means the engine module doesn't like the voltage that it sees on the signal line. The problem could be the knock sensor itself or an open or short in the signal line that runs from the sensor to the engine module. On mini vans, bank 2 is usually the side of the engine that you see when you pop the hood. Knock sensors are usually bolted to the side of the engine block or in the valley underneath the intake manifold. But the wiring harness that connects them can run anywhere under the hood. The lube tech could have damaged a wiring harness when he was ham fisting your air filter box.
    I would take it to a reputable shop, tell them what happened. Get it diagnosed and repaired properly. If it turns out that the lube shop did damage something. Take the bill back to the lube shop and see if they will reimburse you. I recommend taking it to a shop called My Garage in Airdrie.
    I'm usually all over shitting on dealerships. But this time I will take their side. Quick lube shops hire a bunch of uneducated teenagers. Lead by an uneducated adult. It's like the blind leading the blind.
    Dealerships hire the same uneducated teenagers, but are placed in the shop with manufacturer certified master technicians and Journeyman technicians working in the bays around them. They sorta get watched by someone who should know what they are doing. If something does get f'ed up, the chances of it being fixed are a lot higher than just repeatedly clearing trouble codes.
  10. #30
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by Flexray View Post
    And there lies the issue... not only did the OP have his fingers in there now a 2nd shop will. So how do you know who did what? There is zero evidence it falls back on the lube shop and the best course of action is have a shop fix it and chalk it up to an expensive lesson and never go back to a lube shop... unless its for other lube jobs.
  11. #31
    Do we actually think that the disconnection of the air intake caused the knock sensor error?
    I don't.
  12. #32
    Aug 2011
    Strathmore
    2005 Dirtymax
    I don't.
    Unless some idiot really did something stupid and rip a wire or unplugged it then no.
  13. #33
    Sep 2002
    Beyonds Official Realtor
    www.jordanlotoski.com
    I have known the owner of this Jiffy Lube for 15+ years, He runs a good business and if and when at fault has no issue fixing the problem to makes his customers happy. I was just there with my Bronco and service was great.
    "BEYONDS OFFICIAL REALTOR"
    Instagram @jordan_empirewest
    Ranked #1 RE/MAX Professionals (2013-2022)
    Ranked Top 100 Re/Max agent Western Canada (2013-2021)
    Check out my mobile app
    goagent.ca/98F1B2F9
  14. #34
    If your shitbox breaks after an oil change, it doesn't mean the oil change broke your shitbox.
    This.
  15. #35
    Bunch of Honda's
    There’s a couple beyonder owned shops that I use for all my servicing now.
    Steve at VS One and Jackie at Ballance Auto are both A++
  16. #36
    V8s
    For the last >7 years, I've gone pretty far out of my way to take my japanese cars to Jackie.
  17. #37
    Nowhere
    Quote Originally Posted by ganesh View Post
    The quotes I got were 655$ for the first year service, 1800$ for the second year, and 2600$ for the third.
    When I tried to figure out wtf was included I got a speech about how they wear white gloves
  18. #38
    Feb 2004
    Bavaria
    Model 3 Performance
    I'm usually all over shitting on dealerships. But this time I will take their side. Quick lube shops hire a bunch of uneducated teenagers. Lead by an uneducated adult. It's like the blind leading the blind. Dealerships hire the same uneducated teenagers, but are placed in the shop with manufacturer certified master technicians and Journeyman technicians working in the bays around them. They sorta get watched by someone who should know what they are doing. If something does get f'ed up, the chances of it being fixed are a lot higher than just repeatedly clearing trouble codes.
    And the thing about dealerships is that they are doing oil changes on the same vehicles over and over so they have their procedures down and don't have to do any guesswork compared to shops that work on every flavor of vehicle out there.
  1. Jiffy Lube The District NOW HIRING!!
    By topsecret in forum Careers
    Latest Threads: 09-27-2016, 09:39 AM
  2. Jiffy Lube Creekside
    By SkiBum5.0 in forum Mechanical
    Latest Threads: 06-01-2015, 12:47 PM
  3. Jiffy Lube Now Hiring!!!
    Latest Threads: 09-29-2014, 11:51 AM
  4. Jiffy Lube creekside is NOW HIRING!!
    Latest Threads: 02-11-2013, 05:02 PM
  5. Jiffy Lube Scam
    By dj_rice in forum Society / Law / Current Events / Politics
    Latest Threads: 06-01-2007, 07:24 PM
