LF: Hemi Mechanic Recommendation... - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: LF: Hemi Mechanic Recommendation...
    Aug 2004
    Default LF: Hemi Mechanic Recommendation...
    Suggestion for a Hemi (5.7) Mechanic...
    Other than dealer...Well dealer as well if anyone has a recommendation.
    2011 Ram 1500 QC Sport 117000 km
    I have the P0301 code and if it isn't electric I may need some head work done.
    I can swap coils and stuff but if major surgery is required, I need a pro.
    Thanks.
    2017 Jeep Cherokee Limited
    Aug 2019
    Ram truck and some bikes
    That's the cylinder miss fire code isn't it?
    Considering your year and mileage I sure hope its not lifter failure.....
    Unsure of any local mechs that could diagnose this for you.
    Aug 2004
    Agreed...however there is no noticable ping and idle is smooth.
    When it warms up I am gonna swap coils and see if it helps. Good think I am WFH so I don't need to drive anywhere.
    The code is for Cyl #1 so easy to access.
    Mar 2005
    Foothills County
    is faster than yours
    Have you looked at the plugs?
    Aug 2004
    Not yet...
    Baby its cold outside...
    They were swapped about a year a half ago though... Same OEM part #.
    Jul 2008
    Edmonton, Alberta
    2011 Hemi... uh oh.
    Hate to say it, but I think you're gonna be dealing with a lifter failure. Obviously swap coils and see, but given their track record...
    Aug 2002
    992 T-hawk Golf R
    +1 for lifter and cam failure. Fix it soon before it wipes out the rest of the engine!
    PS: Check the oil and cut the filter apart to confirm if there is metal in the pan.
    Good luck!
    I like neat cars.
    Aug 2012
    Non Baller Vehicles
    Call Dave @ Broken Axle
    (403) 237-7706
    He's a domestic truck guy, had my old Hemi Dodge in at him before and he's a good, reliable, honest guy, which is what you really need for a mechanic
    Sep 2007
    A vehicle or two
    Gear Heads on YouTube have an excellent 2 videos on this. The first should be able to help you diagnose- just based in sound. Obviously coil packs are a possibility as you know, but I too am banking on the camshaft issue. Horrible lack of recognition from Chrysler. But if we learned anything from the constant manifold bolt failure of the Hemi, they simply don't care.
    Aug 2019
    Hoping its just a coil pack for you. Interested to know who you go with to diagnose. I've been pricing out Cam swap parts as preventative maintenance. Feel like my 2010 with 160,000km is any day now....
    Plus a new cam would just be a ton of fun.
    Aug 2004
    Broken Axle did some work on my sons Jeep a few years back. Thanks for the recommendation.
    I'll keep it in mind once I try the stuff I can do myself...
    The truck has been relatively maintenance free other that oil changes / tires etc... since I bought it.
    Probably due to throw some $$ at it I guess.
    Mar 2005
    Pushbroom
    Is there enough room in a Ram to pull the camshaft with the engine still in the truck?
    Yes, if this is the same generation model - https://www.youtube.com/watch?v=TIZ27auL0mM
    Aug 2004
    Should be warm enough this weekend to have a look. I had a coolant leak from the water pump a month or so ago and had the WP replaced.
    Plus I am WFH so its not really required for driving right now.
    Hopefully its contamination on #1 coil from the coolant that was sprayed everywhere.
    One can dream right ??
    - - - Updated - - -
    Cripes...from that video it would almost be better to pull the engine.
    ^ I'd still rather do that than pull an engine from a full sized truck. Might as well do other work while youre in there as well - belts, seals, etc.
    Aug 2019
    Hoping its the coil pack for you.
    Aug 2004
    Because it was nice(r) outside, I went out today and cleared the code.
    Started the engine and let it warm up to operating temp. No code return
    Went for a drive around my neighborhood approx 10 kms or so and back to my house. No code return.
    I'll try again tomorrow.
    I'm wondering if I dodged a bullet here...
    Aug 2019
    Good news.
    Hopefully the code stays away.
    Aug 2004
    Quote Originally Posted by haggis88 View Post
    (403) 237-7706
    Broken Axle is temporarily closed while they move shops. Any other recommendations for Hemi Mechanic.
    You tube has diagnosed it as a fuel issue.
    If I turn the key on but do not try to start, it allows the system to build up fuel pressure and than start successfully. Could be that check valve in the fuel pump.
    But a pro can tell for sure.
    Thanks.
  1. Old school Audi mechanic/shop recommendation
    By corsvette in forum Mechanical
    Latest Threads: 10-21-2017, 03:00 PM
  2. Mechanic Recommendation?
    By Feruk in forum Mechanical
    Latest Threads: 09-29-2014, 11:13 AM
  3. Replies: 13
    Latest Threads: 04-15-2012, 09:27 AM
  4. Need recommendation of a good mechanic
    By r0g3r in forum Mechanical
    Latest Threads: 11-28-2008, 03:01 AM
  5. Replies: 0
    Latest Threads: 10-08-2008, 04:15 PM
