switched towers case now it wont start - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: switched towers case now it wont start
    Dec 2004
    (s13 p.o.s 3years +) 97 pathfinder
    Default switched towers case now it wont start
    hey guys, need a bit of help.
    i just got a new tower CASE, i removed everything from my old tower and put it in my new tower case.
    i pluged everything in correctly and the PW jumper.
    so when i went to push the ON button, nothing happend
    so i switched it on the back side.
    all the fans powers up...but i get no BOOT sequence?
    so what am i missing?
    i plugged in the PW jumper, but my ON button doesnt work. everything is hooked up, just like how it was in my old tower.
    Also i tryed plugging my old PS...does the same thing.
    any help would be awsome!
    thanks
    Feb 2004
    check the front panel connectors that go to the MB you may have the connector itself backwards.
    Sep 2007
    A vehicle or two
    Perhaps the power supply in the new case requires an extra connection on the motherboard?
    I recently replaced the power supply in my computer, and the new supply required an additional connection on the MB, beside the main harness....
    Dec 2004
    the only thing i notice differnt is my auxiliary power supply connector on my old PS, which my new one doesnt have one.
    but that shouldnt matter it just provide extra wattage to motherboard...or could i be worng? i tryed plugging my old ps in...nothing powered up.
    Jan 2006
    Axis powers
    then as above, check the power button connector
    Sig nuked by mod.
    Feb 2004
    did you check the front panel button cables and how the connect to the MB?
    it may look fine like you have the pwr cable to pwr spot on the mb. flip it and it should also go in
    Dec 2004
    ps connector
    back of the on/off button
    mobo connectors
    auxiliary
    hd
    pw connector
    Left Coast
    Audi
    What motherboard are you using? I suspect you've got the power switch connected in the wrong place or an extra standoff underneath the motherboard causing a short.
    Dec 2004
    p4xa-bv is my mobo
    Nov 2004
    make sure you have the standoffs in place and your motherboard isn't flat against the case
    Left Coast
    Audi
    Well looks like the power switch is plugged in the right place. how about extra standoffs?
    2020 Subaru Forester Sport
    In all my time working with comps I never seen the power button connect that way, usually it connects horizontally with the edge of the board, but according to the manual I found yours is correct....not sure really
    I found this manual http://www.elhvb.com/mobokive/Archiv...nual/UM-P4X-E1(C).pdf
    on page 35 it shows the power connector.
    Feb 2005
    Fort McMurray
    2003 Subaru WRX Stg. 2
    It looks like, from the pictures you do not have standoffs installed.
    They are the brass things on the back panel of the case that the motherboard screws into.
    Dec 2004
    yeah it was the brass connectors lol
    thanks everyone!
    hahah, in all my days working with comps I only seen this once haha, your lucky you didn't fry the mobo, since you pretty much shorted everything by laying the mobo on metal directly.
    Nov 2003
    I have seen this so many times when I was working at a local computer shop doing repairs.
    Its quite common, either extra standoffs shorting, or no standoffs, or no screws, or random shit spliced into the powersupply.. (seriously)
  1. Unplugged Shaw digital cable, now wont work
    By BigShow in forum Computers, Consoles, and other Electronics
    Latest Threads: 05-02-2009, 06:56 PM
  2. PC trouble (kept shutting down now wont turn on)
    By /////AMG in forum Computer Help Desk
    Latest Threads: 02-24-2009, 03:05 PM
  3. License plate stolen... switched to a texas plate
    By zarge in forum General Car/Bike Talk
    Latest Threads: 05-30-2008, 01:05 AM
  4. Can I keep my Telus Mobility Number if I switched to FIDO?
    By nosegrindR in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-03-2005, 07:33 PM
  5. car wont start
    By 98Max in forum Mechanical
    Latest Threads: 03-10-2003, 06:48 PM
