Fresh air intake duct icing up - anyone have this issue before? - Beyond.ca - Car Forums
Results 1 to 3 of 3
Thread: Fresh air intake duct icing up - anyone have this issue before?
    Jan 2007
    Default Fresh air intake duct icing up - anyone have this issue before?
    A few days ago I noticed a fairly large piece of ice forming on the exterior of the fresh air intake duct in our furnace room. I used a blow dryer to melt the exterior ice build up, however, I can still feel a fairly large piece of ice and a bit of water on the inside of the duct.
    I typically run my furnace fan 24/7, but set it to auto for now in case its making things worse by continuing to bring in cold air.
    Are there any typical causes for this? ie. hole/tear in the insulated duct that's allowing the cool air to meet the warmer air inside my home and then condensate/freeze? Could my duct work be fine and its just the nature of these cold snaps?
    As it gets a bit warmer I'm sure ill be left with a bunch of water inside the duct, is poking a hole to drain it manually a good idea? Or run the fan and try and evaporate it?
    House was built just over 3 years ago. Going to contact my builder and see what they say, but was hoping to get some more input as well as I have little to no experience in the HVAC area...
    Thanks
    Few pics:
    https://i.imgur.com/IqrRpwZ.jpg
    https://i.imgur.com/w4FfIji.jpg
    Fan running 24/7 will not make this better or worse, so go ahead and turn that back on. That's not a combustion line, that's the fresh air intake to your HRV so air is (predominantly) only flowing through that when your Heat Recovery Ventilator is on. IE: when it senses (based on your setting) that your humidity is too high.
    This isn't normal, even at -40, so something is wrong but it's not a huge deal.
    As a quick fix, I'd melt it and then wrap a couple old t-shirts around it, held on gently by twist ties or zip strips. Also put a bucket or tray under it.
    The insulation must be messed up or missing in a patch near there. Builder should fix. The water/frost will most likely be mainly where you see it, not as much inside. (My guess).
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by nagooro View Post
    Thanks
    Few pics:
    There is a hole there somewhere. Could be super small but one exists.
  1. Replies: 15
    Latest Threads: 11-28-2019, 10:05 AM
  2. Fridge Icing up underneath the crisper drawer?
    By nzwasp in forum Home and Garden
    Latest Threads: 10-18-2018, 03:44 PM
  3. Man De-Icing Plane Falls to Death
    By masoncgy in forum Society / Law / Current Events / Politics
    Latest Threads: 12-23-2009, 05:39 PM
  4. GSR my CUSTOM INTAKE DUCT/BOX finished.
    By GSR_aaron in forum Mechanical
    Latest Threads: 06-27-2005, 12:18 AM
  5. air intake duct headlight cover
    By ApexDrift in forum Cosmetic and Styling Modifications
    Latest Threads: 11-30-2004, 07:31 AM
