Post your desktop audio setup - Page 2 - Beyond.ca - Car Forums
Page 2 of 4 FirstFirst 1 2 3 ... LastLast
Results 21 to 40 of 64
Thread: Post your desktop audio setup
  1. #21
    Oct 2009
    rally pig
    out of curiosity, I have an Intel mobo with built-in 7.1 audio and I also have a SB Audigy 2 PCI.
    which one would produce better AQ?
  2. #22
    Apr 2006
    Cowtown
    10' 4Runner SR5
    I always thought the advantage of the SB cards was the optical-out for an external DAC. What are you using to listen?
    Ultracrepidarian
  3. #23
    Oct 2009
    rally pig
    z5500
    using optical to connect to the PS3
    then the 3 regular audio cables to the PC
  4. #24
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Hmm I have a feel it's using the DAC in the PS3 which I'm unfamiliar with. What connections are on the Logitech unit?
    Ultracrepidarian
  5. #25
    May 2004
    Subaru Impreza (White)
    Originally posted by Alterac
    I have these Speakers:
    click for larger version
    http://www.clevo.com.tw/en/products/...?productid=383
    and these headphones:
    http://www.logitech.com/en-us/produc...-sound-headset
    have the same headphones, LOVE them. Can walk around the house without losing a beat.
  6. #26
    Mar 2006
    Legacy Spec B
    Using a Zeppelin Air for my desktop speaker
    And the logitech G35 headset
  7. #27
    Apr 2006
    Cowtown
    10' 4Runner SR5
    I was quite impressed with that unit for what it was. Despite it's rather bizarre shape, the sound was quite nice albeit unable to really reach down low which is to be expected.
    Ultracrepidarian
  8. #28
    Apr 2006
    STi
    I'm using a fiio e17 with Hifiman He-400 headphones for my laptop setup.
  9. #29
    Vancouver
    fiio e10 + denon d2k / triplefi's. deciding on the jaybird bluebuds x for commute.
  10. #30
    2014 GMC Terrain SLE-2 V6
    What connections are you guys using for audio? Headphone jack, or are you guys connecting audio via hdmi?
  11. #31
    Optical off the Mobo for me.
  12. #32
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Depends what gear you have Really, there shouldn't be any difference between an HDMI and an optical link for straight audio because they're both digital signals, maybe slightly less ground noise on the optical if you had the gear to distinguish any differences. However for visual + audio, such as a movie for example, HDMI is actually better from what I understand because it's synchronous.
    If you have optical-out (or coax) on your computer, that optical needs to go to a DAC of some kind. Either a DAC/AMP combo, a receiver, or an external standalone DAC. Many DACs do not take HDMI, I feel like this is a receiver type option.
    Ultracrepidarian
  13. #33
    Dec 2004
    W204
    I am using Asynchronous USB into my DAC.
    http://www.audiophilleo.com/definiti...chronous%20USB
    Along with WASAPI (Windows Audio Session API), I can get bit-perfect info from my computer right into the DAC, so that absolutely no re-sampling takes place (although I suspect output is 24 bits all the time but sample rate will vary according to the file I am playing).
    Should be the purest solution I think.
    Since that pic, I've upgraded my headphone amp to a fully balanced head amp/pre-amp. So from the DAC, it's a balanced setup to pre-amp as well as power amp, and all my headphones are no longer single ended and are set up for balance as well (although discrete L&R is a better way to describe this as it's not really balanced in an audio sense).
    I've also since added a pair of HD800s and Grado RS1i's.
    I'll post a new pic once I clean up my desk hahaha.
  14. #34
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Clem do you know if audio is bit perfect coming off the computer from a network cable, to a squeezebox for example?
    Ultracrepidarian
  15. #35
    Dec 2004
    W204
    Squeezebox is different. The Squeezebox clients get their info pushed from the Squeezecenter (I guess it's called Logitech Media Center now) by the server. The server does all the transcoding, and from what I know, everything is transcoded in real time into PCM/WAV format. I don't know whether it's bit-perfect or not, or if it just uses fixed sample rates like 48, 96, 192 for example. I DO know everything up to the Squeezebox 3 cannot do anything above 16/48, while all the others can.
    Having said that, the Transporter is still one of the best audio streamers money can buy.
  16. #36
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Thanks. I have the Touch and the interface is awesome using my phone as a remote. I'll check into the Transporter. What kind of pricing are we talking about?
    Ultracrepidarian
  17. #37
    Dec 2004
    W204
    I don't even know if you can get them anymore... The original Transporter was $1,999 but they removed the knob and slashed the price to $1,499 LOL. I think at one point they were as low as $999.
  18. #38
    Nov 2003
    The Duet is a good setup also, the Squeezebox Receiver is pretty nice for its price. (Way cheaper than transporter)
    - The DAC from SB3 is a Burr-Brown 24-bit DAC, and the one on the SBR of the Duet is a Wolfson 24-bit DAC.
    - The total harmonic distortion on the SB3 is less than -93.5dB (0.002%) and on the SBR of the Duet is less than -88dB (0.004%).
    http://wiki.slimdevices.com/index.ph...are_comparison
    http://wiki.slimdevices.com/index.ph...zebox_Receiver
    http://en.wikipedia.org/wiki/Squeezebox_(network_music_player)#Transporter_.28September_2006.29
  19. #39
    acura TYPE A
    Logitech Z305 speakers
    they fill the room with audio
    at starbucks i have to turn them off.....
  20. #40
    Jul 2003
    2015 VW GTI
    I use these for music..
    And these for gaming..
  1. Post your home theatre setup
    By JZS_147 in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-23-2015, 11:36 AM
  2. Post your Snowboard Setup
    By DC2uned in forum Sports, Health & Fitness
    Latest Threads: 11-22-2009, 06:31 PM
  3. Post Your Racing Wheel Setup!
    By Skyline_Addict in forum Video Games
    Latest Threads: 09-05-2008, 11:58 AM
  4. Lets see your desktop setup..
    By Boost Infested in forum Computers, Consoles, and other Electronics
    Latest Threads: 02-01-2006, 09:43 AM
  5. Post Your Desktop Wallpapers.
    By DJ Lazy in forum General
    Latest Threads: 02-10-2004, 04:53 PM
