Intercooler core design question - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: Intercooler core design question
    May 2003
    403S
    88 A70
    Default Intercooler core design question
    i would like to know if one of these designs work better than the other?
    #1:
    click for larger version
    #2:
    May 2008
    Airdrie
    '16 Sportwagen
    Number 1 should cool a little bit better because there is more surface area for the boosted air to touch and loose it's heat. Number 2 looks like it has less resistance and maybe will result in less lag? If it means anything the core on number 1 is the same design that is used on turbine engine oil coolers.
    Oct 2004
    AB/NS
    TUBE AND FIN
    Benefits:
    * low cost
    * low weight
    Disadvantages:
    * "effective" lower efficiency compared to bar and plate
    * can be poor quality dependant on supplier
    * is a little more awkward to modify core size
    * some brands are plastic sealed at ends and have limits on welding techniques
    BAR AND PLATE
    Benefits:
    * 35% greater heat sink capability (meaning you effectively COULD have a SMALLER intercooler when compared to the tube and fin)
    * Generally known as the "better product"
    * easy to modify size and re weld
    Disadvantages:
    * weight
    * cost
    * some limitation in sizes
    The tube and fin is a common everyday upgrade due to its low cost.
    The bar and plate is far superior BUT it costs more.
    Edit, and I should point out that the 2nd is a much better cooler, the more area = the more cooling.
    Sep 2006
    +1. #2 looks like that cheap ebay crap everyone says to stay away from..
    dv/dt
    Nov 2003
    2010 Pontiac G3 GT Coupe 1999 Pontiac Sunfire (DD)
    Originally posted by Supa Dexta
    TUBE AND FIN
    Benefits:
    * low cost
    * low weight
    Disadvantages:
    BAR AND PLATE
    Benefits:
    Disadvantages:
    * weight
    * cost
    wow now i'm glad i went with a turbonetics fmic with the bar plate design.
    It is frustratingly reliable, truly the cockroach of automobiles.
    May 2003
    403S
    88 A70
    thanx
  1. Sait : Master Design & Web Design
    By KeepItGully in forum Campus Chat
    Latest Threads: 09-05-2008, 01:54 AM
  2. Replies: 0
    Latest Threads: 02-23-2007, 02:57 PM
  3. Replies: 0
    Latest Threads: 12-10-2005, 01:45 AM
  4. Replies: 9
    Latest Threads: 11-17-2005, 04:49 PM
  5. FS: Intercooler Core
    By legendboy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-10-2002, 03:52 PM
