Backlit house numbers - Calgary? - Page 2 - Beyond.ca - Car Forums
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 50
Thread: Backlit house numbers - Calgary?
  1. #21
    Feb 2009
    Family Hauler
    links?
    google.com followed by aliexpress
    Press enter
    Then in the main search bar type 'backlit house numbers 6" '
    press enter again
    You got this
  2. #22
    Apr 2004
    links?
    https://a.aliexpress.com/_mrfEEme
  3. #23
    Apr 2004
    Well this thread turned me onto an impulse buy lol. Wasn’t really in the market but looks cool and should be easy enough to install
    Not in a huge rush so i ordered from AliExpress. $62 CAD for two 6” numbers and includes the power supply/driver. Hoping I can somehow tap into my sconces on the side of the garage door so that the number lighting will activate at the same time
    So these arrived last Friday the 22nd. 17 days shipping for AliExpress is pretty darn good.
    Quality is ok. If you look closely there are a few blemishes, but since these will be viewed from far away it should be fine. Install looks easy enough - just tap into your 110 on one side of the transformer and then wire in the numbers on the other side.
  4. #24
    2008 Z06
    Nice, quicker then I thought to arrive.
    I ended up going with some 12" non lit ones because I got impatient.
  5. #25
    Jul 2008
    Transnistria
    Exploded.
    Looks like the hardest part is trying to hide the wiring so it looks flush. May you keep us updated on how this goes?!
  6. #26
    May 2004
    Where did you end up finding the 12" numbers?
  7. #27
    2008 Z06
    Quote Originally Posted by lamp_shade_2000 View Post
    $27 per number for 12". Non lit.
    https://www.etsy.com/ca/listing/7840...f=yr_purchases
    Current Cars:
    2004 GMC 2500HD 8.1L
    Past Cars:
    1970 Chevy Blazer, 2wd
    2005 Jeep Wrangler LJ
    1989 5L Mustang
    1990 Jeep Cherokee
  8. #28
    Jun 2007
    ATS, XC90
    Nice. Let me know how the wiring goes. I ended up ordering the front-illuminated ones because it'll be on a black background. Still haven't arrived - stuck in customs right now it seems.
  9. #29
    Jun 2007
    ATS, XC90
    Has anyone installed theirs yet? I finished mine today, and they look great, but holy fack they're bright. I need to tone them down (especially since they're front-lit as the above pic). I'm not sure a dimmer switch will work, but that will probably be my first stab. Anyone had a similar issue?
  10. #30
    Apr 2004
    I finally got around to installing mine yesterday. Mine are backlit so don’t have that brightness problem
    Install was pretty smooth. I drilled a hole through my sconce’s box all the way through insulation and poked through the garage drywall. Then I fished some wire through (the utility marking flags work really well for fishing wire lol) and connected to Live and Neutral then connected to the transformer on the inside.
    Mounting wasn’t too bad. The cutouts they include helped and I taped them to some cardboard for ridgidity. They stick out a few inches which is ok since it allows the light to reflect back. Make sure to get these mounting pieces if ordering from Ali express, I think they were an extra $2 or something. For wiring I did the same thing as the transformer - just drilled all the way through and poked thru drywall
    Not gonna lie it looks pretty amateur on the inside, but it’s the corner of the garage and shouldn’t be disturbed so I’m fine with it for now. At some point I’ll take the drywall off and hide the wires behind. But at the same time I don’t mind having transformer outside wall vs hidden in the insulation…don’t want it to overheat and cause a fire or something.
    Final product looks decent enough. I need to fill the holes from the old numbers still but that’s about it. Not bad for $70 and 3 hours of time.
  11. #31
    Jun 2007
    ATS, XC90
    Nice write-up. I did mine slightly differently, I actually added a plug and wired them to that so I can plug them into the Christmas light socket. Was a bit more of a pain for soldering but I try to avoid splicing into home wiring wherever possible.
    I ordered the white front since I knew they'd be going on a black background. But since I needed space behind, I painted a board with a bunch of coats of black outdoor paint, wired the numbers through that, then added a little box to the back to make space for the wires, and added that piece to the front door. Ran the wiring around and up the back to plug in to the soffet. I'll probably add some sort of cover for the transformer, maybe I'll even 3D print one.
    Name:  68159621938__68104BE9-3C93-4F6A-B5AD-C021A3A44E73 (Medium).jpg
    Name:  IMG_1608 (Medium).jpg
    Gotta clean off the spot where the old numbers were lol. Oh and I didn't have black screws handy, but I did dab some black paint over them after this pic was taken.
    Name:  IMG_1615 (Medium).jpg
    Name:  IMG_1622 (Medium).jpg
    But damn they're bright. I'm messaging the seller to see if there's a plug-in dimmer that will work to bring them down a bit.
  12. #32
    Jul 2008
    Transnistria
    Exploded.
    That's so bright it's useless! Unless the picture sucks?
  13. #33
    Apr 2004
    Nice, I like that backplate you did. Might need to do that when I paint my house hopefully next year.
  14. #34
    Jun 2007
    ATS, XC90
    Quote Originally Posted by flipstah View Post
    Little bit of column A, little bit of column B.
    But yes, still too bright. So far in my head, my options are:
    - adding an inline resistor,
    - adding a dimmer either at the socket as a plug-in, or wiring directly inline,
    - last resort so far is adding some sort of tinted glass cover overtop. Don't like this idea much.
    Thanks! Took me awhile to figure out how I was going to attach the numbers to the house and this was what I came up with. And this is totally removable, with no marks left other than a few screwholes in the wood.
  15. #35
    resistors on LED's don't always work as intended since you might get it flickering before you notice the brightness reducing.
  16. #36
    Jul 2008
    Transnistria
    Exploded.
    I was thinking of doing this too for the front facade, but I have no idea how to seamlessly hide the wiring without drilling from the exterior into the living room. If I tap into the front porch lamp, isn't that forced to be on whenever I do the light switch on/off? So it's not time-based.
  17. #37
    Apr 2004
    Yeah it would be linked. What I did at my place was wire in a Lutron Caseta switch for my front porch and 2x garage sconces and set up timers in the Lutron app. I like having them on as soon as sun goes down, but many times I forgot to turn them off before bed so that’s why I got the Lutron switch. Here’s my schedule with two failsafes in case I turn them back on after 11pm or after midnight for some reason:
    I can’t think of any reason I would want numbers on without the 3 front lights so in my case it made total sense to hook the number lights up to those. If you want them separate, you could do what doozer did and wire them to your exterior plug but then put a timer in between.
  18. #38
    May 2004
    Wyze makes smart switches as well that are a fraction of the cost of the Lutron ones. Should still allow you to set a schedule for on/off with sunset/sunrise
  19. #39
    Yep. They work great. Or whatever the kasa brand ones are. Not too pricey.
  20. #40
    Jul 2008
    Transnistria
    Exploded.
    Ah good idea folks! I’ll do that!
  1. FS: Pink Backlit Game Boy Advance SP (Rare)
    By hexd3mon in forum Video Games / Consoles
    Latest Threads: 01-18-2011, 06:55 PM
  2. backlit house numbers
    By quazimoto in forum Home and Garden
    Latest Threads: 10-25-2010, 01:19 AM
  3. FS: MacBook Pro 15.4" LED-backlit LCD
    By Frostiex in forum Computer Hardware & Peripherals
    Latest Threads: 04-15-2010, 05:59 PM
  4. possible to upgrade laptop keyboard to backlit?
    By trliniar in forum Computer Help Desk
    Latest Threads: 04-01-2010, 04:01 PM
  5. WTB: Backlit Gameboy Advance SP
    Latest Threads: 02-08-2007, 12:13 AM
