I am looking for some formulas to calculate CFM's and then convert it to meters^3/second
Basically I am trying to calculate the rate at which volume of air going into each cylinder is increasing as well as the actual volume as an engine goes through its RPM band from 2K to 8.5K with full boost being made @ 5K boost being 15 PSi.
Trying to model it around B20C but if someone has this already calculated w/ formulas for a B18C5/C1/B that would be prime!!
Thanks, Maybe even links to some/all of this would be good.
My calculas is alright, so if any of you guys already have numbers w/ differentiation, and/or derived formulas, I can work with that too.
Looking for rage2 and Primer_Drift!!!
-Adam
