This quote is hidden because you are ignoring this member. Show QuoteOriginally Posted by SugarphreakThis quote is hidden because you are ignoring this member. Show QuoteThis quote is hidden because you are ignoring this member. Show Quote
Sometimes, those are factory options that are left out of your car because it wasn't upgraded enough ( i have like only 1 of those on mine, and its from the previous carphone which was removed) Rx-7 guys should be able to clear this up.
R.I.P Karol Jozef Wojtyla
Originally posted by A790
I loved the engine, the acceleration. I just hated being seen in the car, that's all.Originally posted by SilverBoost
The realism is like, unbelieveable. Of course if you go to these movies for the killer story line, then you also believe that pornos have great plots.
On the Rhdside, Green 3 lead is Tps checking tap, yellow is fuel pump run jumper tap. driver side is bigger one diagnostic check/ecu trouble code output, smaller is initial set connector for locking down ecu while setting idle speed and mixture.
Too loud for Aspen
So they are all for diagnostics and i dont need to worry?
Yup Well I mean at some point if you are going to maintain the vehicle yourself you'll need to know what they are and what they do, but other than that just leave them alone.
Originally posted by Arash Boodagh
Before I start pwning all the members with my findings.Originally posted by Arash Boodagh
Plus, is it true you can feed a pig elephant dong and it will still grow and build meat?
Toma the homophobe?Originally posted by Toma
rx7_turbfoags best friend
