hey.. my question is, is it possible to hook a turbochargers coolant line to the transmission input and outputs of a radiator? or do i have to tap into a regular coolant line where the water pump moves the coolant around..
and.. where is the best place to run a coolant line on a b16 motor??
and... where is the best place to run oil lines.. ive seen sandwich plates from the vtec solonoid and the oil filter out there, which one do you use?
