The 18-70 is built a little better, but doesn't have as much range and in a lens like that the build quality isn't all that different. I went with the 18-135, both lenses are apparently very sharp and get good reviews. Regardless of what you buy, almost right away you will be wanting another one =).Originally posted by Spike_16v
Ok, so right now it's between the D80, and the 30D.
I'm leaning towards the D80. The question I have is should I get the 18-70 kit, 18-135 kit or the body and the 55-200 VR lense.
Between the 30D and D80 I would definitely take the D80, and it's a little cheaper too. Buying just the body and 55-200vr makes your widest angle about 75mm equivalent on a 35mm camera. If I were you, I would get the 18-70, and then make your next lens the 70-300VR, that lens is only $589 and is absolutely outstanding. Then pick up a SB-600 flash when your ready and you will have a hell of a system covering a large range for a very reasonable price of approximately $2000 total.
