The unique 19" (18.0" viewable) ViewSonic PF790 monitor has it all – high performance in a feature-rich design. Its extraordinary PerfectFlat screen technology eliminates curved surfaces and enhances visual quality by ensuring minimal glare and exciting, realistic images. With an ultra-fine aperture grille pitch of 0.25mm at center and 0.27mm at corner, extremely high resolutions and fast refresh rates, this monitor is ideal for professionals working with graphic intensive applications. ViewSonic delivers innovation and outstanding performance at the right price.
0.25mm aperture grille
This ultra-fine aperture grille pitch produces clear, crisp images with rich, vivid color, even at the highest resolutions.
1600x1200 maximum resolution
Displays a maximum resolution of 1600x1200 at 77Hz flicker-free refresh rate for easy-on-the-eyes viewing. Monitor *WILL* go beyond 1600x1200 resolution, but will only work at lower refresh rates if higher than 1600x1200.
1600x1200 @ 77Hz
1280x1024 @ 89Hz
1024x768 @ 118Hz
800x600 @ 148Hz
PerfectFlat® screen
Absolutely flat screen provides realistically proportioned, precise images with reduced reflection, image distortion and eye fatigue.
OnView® controls including ViewMatch® features
Screen adjustments are made via an on-screen menu using simple controls. This user-friendly control system easily adjusts image quality, size, position and geometry for optimal viewing.
ARAG® screen treatment
This specially formulated anti-reflection, anti-glare screen treatment uses a multi-layer process to eliminate reflection while maintaining the highest image quality.
TCO'99 and Energy certified
This monitor complies with the world’s strictest standards of low radiation, safety, ergonomics, recycling and power management while saving cost through automatic power saving modes.
Plug & Play +
Fully supports the Microsoft® Windows® auto-installation standard for easy, trouble-free configuration and set-up.
PC and Mac® compatible
PM me your offers!
Additional specs available athttp://www.viewsonic.com/products/crt_pf790.htm
