Can i fix this by putting a piece of metal over the crack and jb welding it? or do i need a whole new one? thanks
DONT WELD SHIT!!
get a new one, check around pick your part or bucks auto parts, they should be able to help, last time,at bucks i saw 89 crx with the engine still in it!!but i never checked the oil pan if it was still there..
wheres the leak?
you sure it's the oilpan itself and not the gasket?
if he needs to cover the whole and weld it then i'm guessing it's obvious
No kidding. And I agree with everyone, don't weld, get a new one.
jb weld is like glue, im not gonna be sparking anything
glue??, just get silicone from like canadian tire or som place
1) take out oil pan
2) with a razor scraper or exacto knife, remove all the old gasket or silicone
3) apply silicone all around, dont miss any spot, then bolt on tightly
man...i think a pan at the wreckers will run you like what? $10?
i dont think its that easy to find, and its a crack in the actual piece, probably from bottoming outOriginally posted by rice_eater
just look around , if u cant find it then go to Auto Value, they are always cheaper the most places
i looked underneath today, looks like the leak is coming from the drain bolt. Its tightened all the way though, what can i do?
Get a new bolt, or buy a rubber washer and replace the old one.Originally posted by redline_13000
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
Or just dont drive at 200km/h+ for an hour strait!...maybe that will work! ....j/k
ahah, i wrecked something major when i did that man, the oil leak is minorOriginally posted by James
