Will this buff out??
Not likely.
Doesn't look like it, unless that's white crayon thats scratched on it.
If its deep enough to see under coat or metal = no.
damn that sucks
well actually im not sure if this is under the coat.. its white because it scraped a white pole
try it out
werd ^^ doesnt hurt to try.
it might buff out might not.
if it is just paint transfer hopefully didn't scratch to deeply.
Picture doesn't make it easy to tell. get a better picture. If its paint transfer it will buff out.
Originally posted by TomcoPDR
Wait. Tom, THE Tom?Originally posted by Rusted Bumper
As far as I can tell, tom_9109 has the most detailed and correct answer
I agree with others. If the paint is gouged down to the layer below, it isn't going to buff out. But if the white is just from the pole, it should come off.
Looks like the white is clear coat so you could probably polish it out but you will probably need to remove a fair bit of clear coat in the process which means eventually the paint may weather in that spot.
Maybe...You have nothing to lose..well besides clear, but if you repaint it won't make a difference
Before:
After:
Still a little bit left, but that is about as much as I could do without dramatically shortening the paint life.
Sneek's right - This should clean up pretty nicely. There would still be some marks in the clearcoat, but they would be transparent instead of white.
