ahh im looking into how much for a 10lb bottle to fill and where is the cheapest place to filll it up . someone said I shoudld freeze it before i do anything is this true thanks
Diablo Power Products, speak to Cam they have the cheapest NOS right now even if its in Red Deer,
Nick
Originally posted by rage2
how much is it to fill thanks and who else does it in calgary
Guyon does it in calgary, probably other places as well.
Mopac on 16th
7 bucks per lb around there...
Travel
you should put you bottle in the freezer for like 6 hours before you take it...
Try Davenport behind Varsity chrysler. Not sure how much they charge though...
Empty bottle ..Originally posted by syeve
Why??
Holds more if you freeze it.
By the way, if you want to fill a bottle, can you choose how many lbs to put in, or do you have to fill the whole thing?
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
Till it gets warm and the safety valve starts purging it anyways because the internal pressure gets too high.Originally posted by Weapon_R
Right on Nick you know Cam Great friend of mine, he has an NX filling station and even has an inhouse dyno to test your N20 purschase He's Dr. Lightspeed on BeyondOriginally posted by shadowz
Nick
Red Deer, AB
every time I took my bottle to Guyeon, they froze it and filled it...they told me it could hold more cold...if you want your psi up to like 1100-1200 you need to freeze it...as far as I know, the safety purge is well beyond 1200 psi.Originally posted by 4wheeldrift
About 8 bucks a poundOriginally posted by Boostn
Doesn't hold more the bottle is rated for 10 pounds. Freezing it is how guys with weak pumps or no pumps fill. Over filling it is a good way to have a bad accident. Yes you could put 12 lbs in it but then you risk blowing out your burst valve and now you are done for the weekend till you get another. We use a electronic scale that measures to the .25 once so what ever you want. We also weigh it coming in so we know if you have any left.Originally posted by Weapon_R
I could put 15 in your bottle with a pump will I tho NO.
If your safety startes purging you have a big problem.Originally posted by 4wheeldrift
The reason to freeze it is because they do not have a proper pump set up. A good pump will fill a bottle in 2 mins no waiting around. Most burst valves blow off from 1400-1600. The pressure to run at is 950 at least that is what NX recommends. That is why the bottle heater is good maintains pressure and shuts off when the pressure is exceeded. Keeps consistancy. Excessive pressure is one of the most understood myths in the industry. Most guys think they run faster with more pressure and guess what they do. However the reason for this is that they are actually leaning the car out from the Nitrous manufactures origionally intended jetting this includes wets systems and especially dry. This is dangerous as it will push your afr into another range. (making more power yes but more dangerous). Thus once again giving nitrous a bad rap.Originally posted by syeve
By the way we are 6 a pound. You can watch our scale also no games here.
We are the Nitrous Express reps for this area.
Lookin Good is Goin FAST
"HOME of the AWD DYNO"
