Pictures of some recent projects - Page 5 - Beyond.ca - Car Forums
Page 5 of 16 FirstFirst ... 4 5 6 15 ... LastLast
Results 81 to 100 of 301
Thread: Pictures of some recent projects
  1. #81
    Nov 2004
    In Transit
    2015 MK7 GTI
    Originally posted by Dj_Stylz
    Let me know if the tach goes all weird when it hit's a certain RPM
    It won't be an issue since this distributor is the same obd as the car and it doesn't require swapping coil packs.
    That is why your 01 had that issue, I am doing this on a 97 with a 97 ITR engine
  2. #82
    Oct 2003
    91 PP1 - 93 EH6 - 01 BB6
    His was related to the conversion harness, not specifically the distributor sensor packs. There is some sort of wiring difference between Frog engine control's test rig and our canadian integras apparently.
  3. #83
    Nov 2004
    In Transit
    2015 MK7 GTI
    Rywire man!
    never any issues
  4. #84
    Nov 2004
    In Transit
    2015 MK7 GTI
    Here are a few pics of the ITR swap that went down this weekend.
    No codes, started up right away with no leaks and everything works great
    I'm the midget, EFhatch just towers over me :P
    this will be for sale soon
    Old compressor 8 gallons new one 33 gallons
  5. #85
    Dec 2007
    Airdrie Alberta
    I call dibs on the b18b!!!!!!!
    oh and .....VERY NIIIICE
  6. #86
    Nov 2004
    In Transit
    2015 MK7 GTI
    If you're serious pm me
  7. #87
    A good install, Customer is very pleased he is almost a type r
  8. #88
    Jul 2005
    Tuscany
    1.2 GIGAWATT CUISINART POWERED DELOREAN
    Good work Amigos!
    “I don’t understand bus lanes. Why do poor people have to get to places quicker than I do?” -Jeremy Clarkson
  9. #89
    Nov 2004
    In Transit
    2015 MK7 GTI
    thanks man
  10. #90
    Nov 2004
    In Transit
    2015 MK7 GTI
    Something I worked on today.
    2007 Fit LX
    installed
    Mugen/Showa 5 way adjustable suspension
    Mugen front strut tower brace
    Before bar
    After
    Good night all!
  11. #91
    Nov 2004
    In Transit
    2015 MK7 GTI
    Another project I worked on this past weekend.
    Most of you should be able to recognize this car as Hollie
    Tested the car a few weeks ago and it would not go into gear. Everytime you tried to engage the clutch all that could be heard is grinding.
    We thought it might be something inside the transmission and F20B ones aren't cheap or easy to find...
    So we removed the transmission to have a look
    Nice and clean aside from a lot of black dust
    Once we got the clutch off it became clear what had broke
    Here is me dirty, unshaved and in weekend mode
    Flywheel is in decent shape but has some pretty good grooves
    The pressure plate was well used. Someone had been beating on it just a bit
    Should have part 2 in a few weeks once the new parts are here and we can reinstall everything!
  12. #92
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    I don't know what you are talking about....
    Also just to let you know...it's not actually an F20 trans...it's from an H22....
    ...@therealarifjina...
  13. #93
    Nov 2004
    In Transit
    2015 MK7 GTI
    My bad A
  14. #94
    Feb 2003
    Chestermere, AB
    01 Integra SE / 07 Lexus GS 450H
    Its the Clutch
  15. #95
    Oct 2003
    That clutch disc looks ok from afar... those pieces are from the pressure plate as you may have already deduced. That was an Exedy stage 2 disc by the looks of it?
  16. #96
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    Yes, the friction surface of the clutch is more than ok...But, the springs on the clutch disc as well as the pressure plate are all "fubared"....
    And yes stage 2...
    So Scott, it looks like I will not be needing that transmission you generously offered to me...But I greatly appreciate that offer regardless.
  17. #97
    Oct 2003
    No problem bro.. and hey, if you don't use that clutch disc let me know, I've got the same one and could always use a spare/emergency clutch
  18. #98
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    I cannot in good conscience give away this clutch disc...haha...One of the springs on the hub is about to pop out and the others are significantly worn away...
    If you think you can somehow make use of it...then by all means you are welcome to it though...haha...
  19. #99
    Nov 2004
    In Transit
    2015 MK7 GTI
    Scott those pieces I'm holding are from the clutch disc. They go around the springs to retain them in place.
    That disc is done man
  20. #100
    Oct 2003
    Hmmm looked like bits of the pressure plate to me, not the clutch disc. Tecnically you could just remove the clutch springs and be good to go haha.. unsprung clutch FTW
  1. Some recent photos
    By SpasticDwarf in forum Cars, Bikes, Machines
    Latest Threads: 05-30-2007, 11:36 PM
  2. Replies: 12
    Latest Threads: 08-23-2004, 06:24 AM
  3. Minor Engine Projects
    By hockeybronx in forum Performance Modifications
    Latest Threads: 01-18-2004, 07:55 PM
  4. Coolest lego projects ever..
    By kevie88 in forum General
    Latest Threads: 06-25-2003, 01:02 AM
  5. New Projects ?
    By ConVict in forum General Car/Bike Talk
    Latest Threads: 10-08-2002, 09:04 PM
