I just bought the antec 900 and wanted to drill some holes inside the case so I can mange the wires better. Anyone know what to use to drill these holes?
a drill bit and a drill?
Cos...
waht is the material, hole size, hole depth, .... details / pics
CNC Guru*
Instagram: goreski_rdd
it's the antec 900. i want to drill some holes where u place the motherboard. i've heard about dremels but can i buy these at home depot or is a specific computer tool?
there shouldnt be any drilling in mounting a motherboard to a case
Cos...
ya i know. i'm drilling the holes to manage the wires inside the case.Originally posted by The Cosworth
so get a drill and a drill bit, it is weak aluminum.
Cos...
Ok. I'll try it out tonightOriginally posted by The Cosworth
yeah, it's a computer case, not exactly thick metal, but if you want, the Mastercraft Maximum cobalt drill bits should make quick work of that case
Someday we may need to activate the halo structure off Deerfoot and destroy the North East.
sounds expensive for 1 job. lolOriginally posted by ga16i
i'll try out the drill first
there cheap and worth it from CT - cobalt is good for just about any mat'l
CNC Guru*
but i only need to drill like 2 holes. lolOriginally posted by gretz
might want to invest in some rubber grommets too so the wires don't get sliced.
User title molested by Rage2.
Lay it flat on the floor and drive nails through where you need the holes.
Remove nails afterwards.
Cheap, fast and you get to vent a bit of frustration.
2011 Ram 1500 QC Sport
2017 Jeep Cherokee Limited
that is the nufy way
CNC Guru*
i'll just use some electrical tapeOriginally posted by Thaco
no offense but this sounds like it is going to turn into a hack job.
I have never had to drill any holes in my cases and one of them I built for my uncle was the Antec case with the clear side with watercooling and it looked bloody sharp.
Be careful what your doing
Cos...
the holes won't be big, just big enough to fit a molex through.Originally posted by The Cosworth
that's pretty damn big, you'd be better off taking the molex apart, and put it back on after, that was the hole only has to fit 4 wires, not a big plug.Originally posted by Diesel2005
I didn't know u could take them apartOriginally posted by Thaco
