Command Start
OK so I just bought an older vehicle with Command Start installed and I have a few questions. First off the previous owner had no idea how it works, and I tried playing around with it last night and either the battery is dead in the key fob or something is wrong with the system. Anyways, there is a toggle switch in the car that has three positions, the (Norm) position, the middle position which i would assume is off, and (Lt). The key fob has two buttons on it, but no serial # on it. When in normal and middle position nothing happens no matter what button or combination of buttons is pressed. But once put in the Lt position the car starts without a key and without pressing any buttons on the key fob. It also will not shut off until the switch is flicked back to normal or off. So my questions are does anyone know where i can find the serial # or model # so i can search on the net for instructions, or failing that who sells the command start system in calgary?
