What would be different? Anyone tried it?
hmm, 92-93 is only a b17. Not sure if it would work or not. Most B series stuff is interchangeable
No one knows for sure??
It should be fine. b-series header's will all bolt into place. I believe the only issue is when dealing with oil pan clearances when using a b16 header on b18c's
edit: did b17s have girdles on the block, as this would account for the deeper oil pan? I'm guessing that an ebay header would probably be made the same throughout for bseries and they just make an ad with a different heading
Just checked, doesn't look like it comes with a girdle, so most likely the oil pan has the same depth as b16- b18a/b. Safe bet then if this ebay header is REALLY made for a B17, and retains the same height as a b16 header then it will have clearance issues with a B18C
yours has pistons and rods upgraded but no header? Thats just crazy
LOL... has a header, but the bottom 2 tubes are extremely squashed from bottoming out....Originally posted by crxcel
oh mannn you gotta watch those calgary streets man!!
