I was doing some spirited driving last night and suddenly it was hard to get into gear. I had the problem arise before, and it would go away if I let the car cool down. It happened quite a bit in the past. So I checked the fluid, and it was all mucky and brown which I thought was odd as the fluid was changed just in the spring. When I had a 5 speed conversion done. I changed the fluid, and swapped out the slave cylinder for a new one just as a precautionary. The Master cylinder looks to be a new one, that was provided when I got the 5 speed conversion.
Well anyways, shortly after I had issues with getting it into gear easily last night, my clutch started to slip. Wtf I thought. The clutch had less than 3000 KMs on it, a Centerforce Dual Friction. So I quickly drove it home and parked it in the garage. And it was late so I didn't start looking at the potential causes till this morning.
This morning I adjusted the clutch pedal, so it engaged lower down. I had a feeling that the pedal had the engagement point too high and it may have been preventing the clutch from fulling re-engaging when I let off the clutch pedal. Then I checked the fluid again, it's mucky brown again (what the hell? I changed it less than 1000KMs ago w/ a new slave). I didn't change it out as I had no turkey baster to remove the dirty fluid.
I test drove it this morning, and everything seems to be ok again. Pretty sure my clutch got a bit glazed from the slipping last night though
Anyone know why my fluid keeps going brown though?
