Bodywork need a quick questions answered - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Bodywork need a quick questions answered
    ___________________________
    Default Bodywork need a quick questions answered
    Ok so ive completed rust removal stage 6 on my ae86 , all the old rusts spots are now down to bare medal and sanded fairly smooth other than some pits fom the sandblaster..now in order to prevent the metal from rusting under the paint once painted what do I cover it with? Do I spray the bare metal with some self etching primer then bondo or do I bondo on bare metal then smooth and prime? thanks for the help
    Red Deer, AB
    Feb 2003
    DT 780
    LEXUS LX470
    i was talking to my friend who did the work on my rear quarters. he said after he sanded down to bare metal he applies a special primer... may have been acid primer? and then lays the color and clear. make sure there is no rust inside the quarters as well.
    edit: sorry i didn't answer your question. i'm not sure if you bondo then prime. i think you need something on the metal before the bondo to make sure it adheres well.
    Tap, Rack, BANG!
    6.7 CUMMINS, E50 AMG
    you need to use a rust converter on all the bare metal. that converts the remaining rust (cant see) to black primer. then use some sort of etching primer on the bare metal.
    T2S
    pedals
    If the rust is gone then you can start with the putty. Make everything smooth and then primer. If you have a few spots that are particularly bad, there is a product called all-metal that can help you out. It is a putty that basically takes the place of rusted out metal. Its not really good for big holes or anything, but for rust pitting and even pin-holes its perfect. I used it on the window corners on my microbus and havent had any problems yet (painted 1 year ago august)
    As for the backside. If you prime it make sure to paint it as well as primer over time obsorbs moisture and it will rust again. So make sure you seal the backside. A layer or 2 of paint then rockguard wouldn't hurt. All that can be done with spray paints as its on the backside of the panel so a PRO- job isnt nessisary. Unless you want to pay some dollars to paint the inside of you panel.
    '07 Ranger FX4 Level II
    Try and find a product called "rust-mor" by SEM. IT stops the rust thats you can not see. Its takes 2 coats with 24hours cure time in between each coat. If you can not find any let me know and ill hook ya up with some. Then follow with etching primer ect...
    (is your garage heated?)
    Originally posted by rage2
    Bunch of Honda's
    por 15 tons of people swear by it
    Jun 2003
    Calgary, ab
    Hemi, ZX6R
    Wow everyone is saying different things, lol.
    Haha yah everyone has a different cure for rust..ninspeed where can I find this stuff? HJR, I also had trouble finding all-metal..my Calgary garage is not heated, hopefully it will get nice in the next week or so
    Red Deer, AB
    I bought a metal conditioner from acklands..basically prevents rust from forming under the paint. Its a dupont product..says can cause central nervous system damage..Im sort of scared to use it haha
    Red Deer, AB
    does it smell like acid??? cuas the sem shit says the same thing
    Haha dude it says not to inhale fumes or it will damage your brain haha it actually says that..its some sort of acid..a wipe on wipe off substance..btw thanks for leading me to the right place ninspeed
    Red Deer, AB
    well they say not to alot of things that i do, well do... ha ha ha, that is starting to explane alot
  1. I need bodywork done, Help!
    By Speed_RaSiR in forum Mechanical
    Latest Threads: 09-05-2003, 10:24 PM
  2. Two quick questions....
    By ninjak84 in forum General
    Latest Threads: 02-01-2003, 02:32 AM
  3. DIY Bodywork :)
    By Arthur Dent in forum Cars, Bikes, Machines
    Latest Threads: 10-24-2002, 07:11 PM
  4. bodywork
    By dj_honda in forum Mechanical
    Latest Threads: 09-28-2002, 03:03 AM
  5. anyone good with bodywork?
    By Soren in forum General Car/Bike Talk
    Latest Threads: 06-22-2002, 12:51 PM
