Harris 1A2 12-25" Bipod for sale. In great shape.
$90
SureFire Millennium M500A Colt Rifle WeaponLight replaces the weapon's original handguards and features built-in switching without any exposed wiring. Because of its lightweight and integrated design, this SureFire Weaponlight is most recommended for urban law enforcement applications and civilian home defense. Each Millennium Colt Rifle Dedicated Weapon Flashlight from Sure-Fire is equipped with three separate switches: (1) A pressure sensitive momentary activation pad (2) a constant-on switch, and (3) a system disable switch to lock the weapon light in the OFF position for covert operations or to eliminate accidental flashlight activation during storage. SureFire M500A Millennium Forend Weaponlight is powered by three lithium batteries and produces 125 lumens for one hour of runtime with the high-output lamp, or 225 lumens for 20 minutes with the included ultra-high output lamp.
Features of Surefire M500A Millennium Forend Weapon-Light :
* Batteries - Three SureFire lithium SF123 3.0 Volt with 10-year shelf life
* Lamp Assembly/Runtime - SureFire MN10 xenon/halogen gas-filled lamp assembly with 125 lumens output for 60 minutes, or 225 lumens for 20 minutes with included Sure Fire MN11 ultra-high output lamp assembly
* Construction - Nitrolon (non-conductive, impact-resistant, aramid glass-filled polymer) housing, Pyrex lens window, shock-isolated aluminum bezel with hard-anodized finish
* Switching - Pressure sensitive momentary activation pad, constant-on rocker switch, system disable rotary switch
* Flawless white beam, always in focus
* Bright enough to temporarily blind an opponent
$240
I have a NIB Volquartsen Custom Picatinny Scope Mount (Black)
This scope mount is a no-gunsmithing mount for the 10/22 receiver. It is CNC machined from an aluminum alloy to Picatinny specifications. The scope mount is .480” tall to allow the mounting of larger objective scopes. An extended length of 7” allows for a more versatile mounting platform in addition to the 17 cross slots machined into the mount. The mount extends approximately 2” forward of the receiver to facilitate the mounting of a wide range of optics. Includes four mounting screws.
[VC10PR-B]
Asking $40
Have an extra ERGO AR15/M16 Tactical Grip in black for sale
$SOLD
Nice LEDWAVE Z-5 TacLite Rail Mount Flashlight
Model: Z-5 Tactical
Power Source: 2 CR123 Batteries
Light Output: 65 Lumens
Weight: 4.1 ounces
Light Color: Bright White
Features: Variable Switch
$65
