Originally posted by 5000Audi
cheak the tranny fluid level.. might be low so not enough oil to make the gear change
Im on my 8th Jeep and I have had this problem with a few of them. For all of them it has been low/old/burnt trans fluid. Do a fluid change with screen and make sure you clean all the metal shavings and film off of the magnet in the pan. I also recommend a transmission additive for the higher kms. ( I used slick 50) Its a fairly easy job to do. Just make sure you torque the bolts on the pan properly and check them after a few weeks as it will start to leak. Make sure to remove all the old gasket off the pan...
I MAKE BALLER CARS MORE BALLER.....
