Complete turbo drivetrain from a 2007 Mazdaspeed 3. All parts have 33000 kms on them. Included is the engine along with all the accessories such as alternator, power steering pump, AC compressor; engine mounts, intercooler etc.; transmission along with both axles (one of the axles needs a new CV boot clamp); turbo; radiator, all exhaust pieces ending at the downpipe, steering column, shifter linkages ECU along with matching key, gauge cluster, dash board buttons. Has Mazdaspeed oil cap and clutch master cylinder (OEM red anodized aluminum).
Any other parts NEEDED to get the engine running will be included but YOU must do the research of what is needed and let us know what you need. Having said that we will give you a start up money back guarantee as long as you DO NOT open the engine (conditions apply please call Peter below). We drove this car around when we got it into and out of the shop. It ran perfectly with no check engine lights on or anything.
Total price for everything above is $4500
Also available at an additional cost:
-power steering rack, cross member, sway bar, control arms, spindles, brakes and brake booster. Will part brakes and brake booster separately if wanted.
Price: $800 for everything
-Mazdaspeed front and rear seats along with all four matching red stitched door cards. Also included in this price is the complete BOSE speaker system in the doors, under seat subwoofer and amplifier.
Price: $750
-hatchback front end including hood with scoop for intercooler, fenders, front bumper with fog lights (bumper has a crack), bumper rebar, HID headlights with wiring and leveler switch, airbags with controller and accelerometers along with any other miscellaneous brackets needed.
Price: Negotiable
-TIEN SS 32 way adjustable pillow top mount coilovers fitting 2007 and older cars. Have the ability to be controlled from inside the car however included is only the manual adjusters.
Price $750
We also have any miscellaneous dash/interior pieces if anyone needs anything. Please call/text message Peter at 780-709-5060. If there is no answer then try again a few seconds later. Please do not leave a message. At last resort PM/e-mail me here.
Block heater/cord included as well
