Tranny Drain plug - Beyond.ca - Car Forums
Results 1 to 18 of 18
Thread: Tranny Drain plug
    Dec 2002
    2004 Toyota Echo
    Default Tranny Drain plug
    I'm slowly learning how to do things on my own. I'll be changing the tranny fluid soon and I looked up the procedure on changing tranny fluid from Haynes Auto manual. From the diagram, I can't decipher which bolt to loosen.
    Thanx
    2004 Toyota Echo
    Dec 2002
    2004 Toyota Echo
    Also, does a filter need to be replaced as well? Location?
    2004 Toyota Echo
    The second picture is the drain bolt, the first picture is the fill bolt. Here are the steps to replacing the tranny fluid, which should be completed while keeping the car level:
    1. Remove the filler bolt (the top one half way up the front of the tranny)
    2. Place a drain pan under the bottom drain bolt
    3. Remove drain bolt and drain the fluid
    4. Once drained, put the drain bolt back in and tighten.
    5. Run a hose down and into the filler hole, and connect a funnel to the hose.
    6. Begin filling the tranny until fluid begins to come out of the filler hole
    7. Put in the filler bolt and tighten.
    Also there is no filter in the tranny
    Dec 2002
    2004 Toyota Echo
    Thanx for your help 4G63 Power. I think I may of screwed up. I thought this pic was the tranny filler.
    And I filled it with 3 litres of fluid. Could this become a problem?
    2004 Toyota Echo
    I can't remember the quantity for a FWD tranny, but for an AWD tranny it was under 3 litres.
    Dec 2002
    2004 Toyota Echo
    Would it be ok for me to drive til next week?
    2004 Toyota Echo
    2005 S50
    Like 4G63Power Said always open the filler bolt before drain bolt, because if you drain the fluid but the filler bolt is siezed u'll be fucked Royally.
    Brocket
    B18C5 neon -|-y|>3 r
    that's a lot of oil you got on your bell housing...since your talon is pretty close to a neon i'd say the quantity of fluid is 2.3L like for me. Anyways when you get your tranny fluid FROM THE DEALERSHIP ask them and they can tell you exactly how much, though it's probably in your owner's manual. I've never heard of a filter for the tranny though. Maybe the neon is to welfare to have one. ANyways i would have guessed that it's the bolt in the first picture that is the drain plug...the second looks like a mounting bolt to me
    Aug 2003
    Okotoks
    Yes because everybody knows that if you punch a hole half way up the side of a jug of milk... the whole container will magically empty
    You don't wanna race me.... you've seen taillights like mine a thousand times!!!!
    RIP T.T. Feb 09 2004
    Dec 2002
    2004 Toyota Echo
    I finally got the bolt off from the first pic and drained the excess fluid I put in yesterday and tomorrow I'll be completely changing the fluid to GM syncromesh.
    BTW, does GM syncromesh have different viscosities? Or is it just the ONE type?
    2004 Toyota Echo
    Feb 2003
    DT 780
    LEXUS LX470
    there are two different syncromesh
    regular part# 12345349 ac delco #10-4006
    friction mod part# 12377916 ac delco # 10-4014
    i believe friction mod is best for lsd
    Tap, Rack, BANG!
    Dec 2002
    2004 Toyota Echo
    What is lsd?
    2004 Toyota Echo
    Feb 2003
    DT 780
    LEXUS LX470
    oh sorry. limited slip differential.... is your car awd or fwd?? i'm not sure about mitsu's but the hondas that we get here don't come with lsd except for the type r. my car has an open differential aka garbage
    Tap, Rack, BANG!
    Dec 2002
    2004 Toyota Echo
    mY CAR IS A FWD. Not sure about lsd.
    I heard that gear with HYPOID eats syncros. Anytruth in that opinion?
    2004 Toyota Echo
    Brocket
    why are you using GM stuff? aren't you supposed to use mopar stuff? i know on my neon the only stuff i can use is the mopar, as everything else is junk
    '07 Ranger FX4 Level II
    you are a really close minded person, No, you do not need to ONLY use mopar stuff in your car.. you should only be using NuGold...
    Sep 2003
    Calgary Alberta
    '99 cbr 600
    Originally posted by Daxin
    What is lsd?
    lysergic acid diethylamide
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    The GM Stuff, and REDLINE Fluids have been tried and tested with DSMer's for a long time...with great success with both...
    ...@therealarifjina...
  1. where is the radiator plug to drain my radiator?
    By EstoMax in forum Mechanical
    Latest Threads: 09-27-2003, 08:34 PM
  2. Best Spark plug???
    By GingeRRRBeef in forum Performance Modifications
    Latest Threads: 10-04-2002, 06:50 AM
  3. Just a plug.
    By 5.9 R/T in forum General Car/Bike Talk
    Latest Threads: 08-01-2002, 09:55 PM
  4. Aem Plug And Play - Tuners Needed!
    By choweyt3t4 in forum General Car/Bike Talk
    Latest Threads: 06-24-2002, 11:35 PM
  5. Spark plug and wires
    By Ferio_vti in forum General Car/Bike Talk
    Latest Threads: 06-24-2002, 10:03 PM
