Just In Time For Snow[
I have 3 Awesome peices of equipment, need to sell because car in major project this winter. I have Ride Ex Bindings/ Forum Jp Walker Boots/ and Mens Session pants. I will sell each for the set price or the whole lot for 400....Why SO cheap....Cause I need it GONE!!
02/03 Forum Jp Walker Boots: Used 2 times bought at the source last year paid over 300 will settle for 200Obo
Info:
The JP Walker Pro Model boot was designed to look as dope as possible and have every technical feature needed to make a killer boot. With this in mind, Forum added Dual air (toe and heel) pockets for cushioned landings, and inner lacing for anti-heel lift. JP also wanted more protection around the heel cup area, so refinforcement was added to the back of the boot with a durable rubber heel cup. An arch support was added to help ease foot fatigue and boot stretch, as well as a super technical treach for mad traction on all types of snow and ice. JP also added velcro on the liner and tongue to stop the tongue from slipping around throughout the day. This all came together for one sick boot!
OUTSOLE
*Durable and flexible gum rubber outsole
*Stitched toe and heel
*PVC arch support to prolong boot life & avoid foot fatigue
*Separate toe and heel sections for proper boot flex
*Super grippy tread pattern and flex grooves for proper hiking.
MIDSOLE
*Full length polyurethane midsole for cushioning
*10psi nitrogen-filled airbag in the toe
*30 psi nitrogen-filled airbag in the heel
*Molded arch for lively boot flex and support
UPPER
*100% synthetic upper for lightweight, better waterproofing and longer boot life
*Rubber heel and calf protection with thermal polyurethane inserts for added durability
*Metal mesh with waterproofed backing
*Reinforced heel and spine support
*Reinforced upper padding for proper support
*Lace loops with nylon lining for durability
*Removable inner ankle harness
*Nylon rip-stop lining to insure waterproofing
*Recessed ankle lace loop for snug heel hold
*5-layer tongue with polyurethane core for comfort and snug fit
*Neoprene cuff recess for calf pressure relief
*Custom-molded metal lace hooks for quick lacing
*Hockey style laces for tight lacing and no hand hurt
LINER
*10mm thermal moldable foam liner with fleece lining. This Forum Intuition Thermal Liner uses an outer Lycra covering for durability and a fleece liner for comfort and warmth. Both of these fabrics are four-way pliable to allow the inner foam material complete freedom to properly mold to the foot.
03/04 Red Ride Ex Bindings: Bought for this year...was planning on going big Never used, are still brand new in box....spent over 325 on these will sell for 250Obo
Info:
Brand spanking new -never used -2002/03 Ride EX binding -color: viper red chrome(as shown) -size: Large, fits mens sizes 8 to 14 and womens 9 & up -suggested retail over $200 -cored shaped anatomical baseplate -6061 T6 Aluminum baseplate provides lightweight responsiveness with added padding under critical foot load areas -quick adjust heelcup custom fits toe to heel centering on your board -adjustable drive plate toe ramp for powerful toeside leverage with shock absorbsion-new anatomical aluminum ankle and toe zip ratchets with grip pods -pre-curved ankle straps with trimless adjustment wrap your foot evenly and locks in place securely for fit, comfort and response -Comfy cushioned bubble ankle pad relieves pressure with load distribution -quick adjust , trimless toe straps -rebound rod stance correct highback -dual density ankle padding -ribbed highback with tool-less quick release forward lean adjuster -stainless steel hardware resists corrosion -new response disc fits 4 hole patterns
03/04 Grey Mens Sessions Pants: These are a size large...I used them once...but only to walk around in last year to get the feel. I paid over 200 for these last year will settle for 150Obo
Info:
Features:
- 100% taped seams
- highback neoprene waist
- elastic tab waist adjusters
- double snap front closure
- standard fly
- gusset crotch
- zippered hem gusset
- corded inner leg venting
- articulated seat
- articulated knee
- front hand pockets
- cargo/utility pockets
- fly stash pocket
- integrated suspension gaiter w/ boot hook
- Tuff cuff reinforcement
- heel plate
- d-ring
Shell Fabric:
- 100% Nylon Medium Twill
WP/BR Technology:
- Active Tech 10000/8000
Lining:
- Light Mesh
These pants have two normal zipped pant pockets, two thigh zippered packets, and two zippered lower leg pockets. There are also zippered vent openings between the legs. The waist band has elastic and side elastic/Velcro adjusters. The front of the pants has two heavy duty snaps at the waist and a normal zipper.
***********Pics**********
