How to conserve laptop battery life on roadtrip? - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: How to conserve laptop battery life on roadtrip?
    Feb 2009
    Airdrie
    Default How to conserve laptop battery life on roadtrip?
    I have a fairly lengthy road trip comming up, and would like to take my laptop with me to entertain me for at least half the trip.
    usual battery life I can get out of my macbook with wifi/bluetooth off and dim screen is about 3 hours.
    my question is: will using a usb flash drive with movies on it save me more battery, than having to run it off the laptops hard drive? or does the usb port pull significant power either way.
    Yeah it'll help. But you can get a power inverter for the cig lighter for like $20.....
    dv/dt
    Jul 2007
    Blue boy
    also dim your screen down if you can
    Feb 2008
    teslo murdel free
    buy another battery if it's not one of the newest gen ones
    Feb 2009
    Airdrie
    I should have mentioned I'll be taking the ride through Greyhound ~5 hours.
    Yeah, like I said bluetooth/wifi/dim screen....any other points?
    it is the new aluminum gen.
    Oh. Then... power inverter + small car battery? :P
    dv/dt
    Dont use your wifi / bluetooth / cdrom / screen dim / no antivirus running (makes harddrive spin extra more ) / basically close everything except 1 program.
    Default Re: How to conserve laptop battery life on roadtrip?
    The problem with running movies off of a flash drive is that a lot of background services will end up using the hard drive every now and then. This will prevent the hard drive from entering it's power saving spin-down mode.
    What you can do though, is install a Linux-live distribution to the USB stick, and boot directly off of that. You will want to use Linux's "Laptop Mode Tools" to enable the power saving features in Linux.
    Also, if you are watching movies, try and avoid H.264 movies. These require a lot of processing power to decode and as a result will eat up your battery.
    Last, make sure your vents get a lot of air flow. The more you can avoid running the cooling fans, the longer your battery will last.
  1. Welcome" Roadtrip from Jan26-Jan28
    By 2BLUE in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 01-14-2007, 03:11 PM
  2. Anyone up for a roadtrip???
    By harley11 in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 12-06-2006, 03:25 AM
  3. First roadtrip
    By Neon guy in forum Events and Meets
    Latest Threads: 12-13-2005, 09:32 PM
  4. Conserve water!
    By SuPhistiKatEd in forum General
    Latest Threads: 06-27-2005, 08:01 PM
  5. Porsche Roadtrip... yikes!!
    By xkon in forum General Car/Bike Talk
    Latest Threads: 01-05-2004, 04:19 PM
