Official Short-term Investments Thread - Page 1587 - Beyond.ca - Car Forums
Page 1587 of 1778 FirstFirst ... 1577 1586 1587 1588 1597 ... LastLast
Results 31,721 to 31,740 of 35560
Thread: Official Short-term Investments Thread
  1. #31721
    Jul 2006
    Victoria Park
    Let gold consolidate for a day or so before moving higher. I will be adding/averaging up my positions in JNUG during this period
    Likely Friday afternoon entry or probably sometimes next week after Sept 11th.
  2. #31722
    Jul 2006
    Victoria Park
    Well, that was a short consolidation period... Gold 1349 spike!
  3. #31723
    Mr. Forex technical
    a tank
    already have 1 small position in UGAZ under 12, adding another position here with stop. if natgas breakout was real, it needs to rally from here
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  4. #31724
    Mr. Forex technical
    a tank
    gold
    well as posted earlier this week, gold has finally got to the 1350 area. I fully expect this to be a short term top. while dollar's sloping neckline is near 90, if there is one quick panic drop to retest that area, gold may give us a false breakout above 1350.
    I have exited my leverage position to look for a better entry. if gold does make a push above 1350, depending where the miners are, I may reduce some core positions. over all not going to make the same mistake I did in early 2016 when I completely sold all my shares only to see gold/miners continue to rally hard for another 2+ months
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  5. #31725
    Mr. Forex technical
    a tank
    mux (mux.to)
    switching to mux USA simply it has more liquidity and the chart is easier to see.
    mux.(mux.to)
    I am pretty sure wave (C) bottom is in, a beautiful 5 waves off the low. sure it may be in an extended 3rd wave or 5th wave. Either count looks bullish to me. If gold does pull back from current level while the US dollar makes a strong rally just as everyone has given up. this may give mux.the wave 2 pull back then the next move up should be dandy
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  6. #31726
    Mr. Forex technical
    a tank
    fcx
    has copper topped and in a correction? I think so. but looking at fcx, it appears it is flagging. we may have an extended 3rd wave which means fcx can still breakout of this flag and make one more higher high above 15.70. The only alt count would be wave (i)(ii) is actually a truncated 5th wave bottom. if this is the case then we would see fcx possible back filling the gap near 13 in the coming weeks in the orange count.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  7. #31727
    Mr. Forex technical
    a tank
    Meg.to
    I already have position in bte and will diversify my energy holdings trying a position here in Meg.to, if we have a 1-2, 1-2 setup off the low, this sub wave 2 should end around 4.79. the alt count in orange would imply we are part of a larger degree corrective pattern targeting down to the low 4s which only means a better buying opportunity imo
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  8. #31728
    Mr. Forex technical
    a tank
    gold
    so far gold did make a push above 1350 and as suspected, came crashing down. this could be a false breakout now triggering a daily cycle pull back with a chance to back test 1300 again. However following some other EW counters, the more bullish implication still pegs gold having the ability to push all the way towards the 1380 zone. Which means any pull back now could be shallow. Personally I will only get back into miners if gdx can back test the 24 area. So no harm in either direction where gold will go.
    copper
    looks like copper has finally made a good drop which could be just the initial leg down. I have sold fcx in the 15s, and will wait for re-entry in the 13s
    natgas
    natgas couldnt rebound and now looks like it wants to retest or break below the 2.86 area. I will hold onto my position a tag longer with stops under 2.75
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  9. #31729
    Mr. Forex technical
    a tank
    fcx
    here is an updated look at fcx big picture count. a very solid 1-2, 1-2 setup. Currently in an micro wave 4 of 5 of (i). very possible we should see a break above 15.70 to end the initial leg up before a more lengthy correction. wave (ii) to (iii) will be the one you want to be in.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  10. #31730
    Mr. Forex technical
    a tank
    gdx
    big picture count on gdx. with the way gold is moving and closing strongly above key resistance area. the momentum is extremely bullish with possible big upside move (aka POR point of recognition) is coming. this will happen when gold or miner moves in such a big way that will surprise everyone and that is when the general public begins to realize the recent moves are for real.
    because miner has been in correction for quite some time, the various 1-2, 1-2 setups will create multiple sub waves after sub waves. But the green count should remain the outlook as long as gdx does not break below 23.67. If it does it will be an early warning sign that something is wrong. And final bearish confirmation if price breaks under 21 would open up the very strong possibility of testing and breaking below the 2016 December low under 18.58. The orange count will be the bearish alt count. again the way things are shaping, my feeling as well as many EW counter is that gold/miners are in an early stage of a major up cycle shall price prove it wrong otherwise.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  11. #31731
    Mr. Forex technical
    a tank
    Quote Originally Posted by SilverRex View Post
    gdx
    countwise I think we are coming up to a sub micro 5th wave finish. yes it can still make a higher high but I am going to take my profit on Jnug after 20%+ run up. Sold 24.955. I will wait for a wave sub iv pull back that should be able to back test the previous trendline breakout as well as revisiting the previous wave 4 low. Since it looks like this wave 3 is extended, we should have multiple wave iv making it a bit choppy.
    well reposting a previous chart. we finally saw gold pull back the way it should after producing a false breakout above 1350. I am waiting for gdx to see if it can drop into the low 24s so I can re-enter Jnug.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  12. #31732
    Mr. Forex technical
    a tank
    increasing my position size on USA.to during this pull back
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  13. #31733
    Mr. Forex technical
    a tank
    bte.to
    possible 1-2, 1-2 setup and backtesting
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  14. #31734
    Mr. Forex technical
    a tank
    with gold coming down. if a daily cycle top has formed just like the previous reversal pattern (circled in red) then price should eventually break the red rising trendline for a sub wave 2 correction landing some where between 1260-1298
    to confirm this, gold needs to break below 1324 and invalidate the current count to the upside. of course, assuming the US dollar fails to break above 92.11 (which is my land in the sand before believing a short term bottom has formed) any further new lows on the greenback would again push gold to further highs with the next target in the 1370-1380 range. If this happens it just means the next backtest will fall into the 1280-1313 range simply the blue box just moves higher.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  15. #31735
    Mr. Forex technical
    a tank
    scaling back into fcx if this is a sub 4 of 5 correction
    natgas looking good again
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  16. #31736
    Mr. Forex technical
    a tank
    usas (usa.to)
    stepping back, the chart looks fantastic with a huge ihns pattern at play. A breakout above this neckline would put down a price target into the 8s. I want to see if it can produce a breakout above 4.50 on volume, then a backtest before launch.
    USAS backtest sucessful. looking for it to push higher
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  17. #31737
    Mr. Forex technical
    a tank
    fcx
    count remains valid. so far price has reached low enough to suggest a possible wave (iv) bottom. with wave 4 we should see one more wave higher than 15.70 in the coming weeks. I have scaled in one position at 14.25, since price can often retrace the prior wave iv low at 13.82, I will open another position if price does produce one more drop.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  18. #31738
    Mr. Forex technical
    a tank
    gold/miner correcting as expected.
    natgas looking good
    bte/meg looking good
    fcx making a final move under 13.83 imo, might add another position if it can break below this
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  19. #31739
    Mr. Forex technical
    a tank
    gdx
    my current count on gdx. the line in the sand for me is 23.68, amazingly the 61% low lands right at 23.68 for the wave (iii) rally. hence until this breaks to the downside, I will remain in the camp this move down is corrective and looking for a wave (iv) low. it could be a sharp move or could grind out for another week.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  20. #31740
    Mr. Forex technical
    a tank
    gold vs Japanese yen ratio
    this is another chart I have been paying attention too of late.
    ever since gold topped in 2011 and began a 4 year correction. this pair has been pretty much in sync ever since. the moment gold out performs the Yen is when gold begins a new bull cycle. clearly we have some bullish momentum, I see the pair at least testing the upper wedge neckline which will then cause a pause for a good correction. I think this may entail that gold can still surprise which would line up well for the current count in miners taking it up for wave 5 topping. imo
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  1. The Official Trump Thread
    By ZenOps in forum Society / Law / Current Events / Politics
    Latest Threads: 04-19-2018, 04:00 PM
  2. The Official ~Your Office Pic~ Thread
    By legendboy in forum Careers
    Latest Threads: 05-29-2003, 09:24 PM
  3. Replies: 14
    Latest Threads: 04-09-2003, 12:28 PM
  4. The "Official" who is going to win the cup thread!
    By Speed_RaSiR in forum Sports, Health & Fitness
    Latest Threads: 04-08-2003, 10:41 PM
