Hello.
I was in a car accident with my 2003 2 door Civic Coupe in which I ended up going over a short guard rail. Part of the damage was a pushed out driver rocker panel, and a dented in door frame on the drivers side. The door frame damage is only evident on the bottom.
The driver door wouldn't close due to the pushed out rocker panel, so I took a hammer and knocked the panel in enough so the door closed properly. However, since the accident, my door locks no longer work properly.
Using my main and secondary door remote, the doors won't lock, and only open about 1 in 20 tries. Using my main and secondary keys is of little help, as either key won't insert into the driver door lock, and I usually can't get the keys to insert in the passenger door lock.
I suspect something is binding in the lock mechanism on the driver side, so I'm going to take off the door panel and inspect the lock system.
Does anyone have advice or suggestions before I proceed?
Thank you.
