D16A6 Non-Vtec turbo Build. - Beyond.ca - Car Forums
Results 1 to 20 of 38
Thread: D16A6 Non-Vtec turbo Build.
    Dec 2008
    Is way to loud.
    Default D16A6 Non-Vtec turbo Build.
    Going to start building a turbo D16A6 non-vtec.
    any suggestions on best internals to use.(Pistons,rods,crank,head,etc.)
    injector size.(i know their is going to be alot of comments on how stupid i am for this.but i am looking to run 2.bar of boost=28PSI)
    Not sure what to run for CP ratio for pstons.8.0:1 CR??? not sure.
    fuel system suggestions,cooling,Tuning.
    What turbo should i run,any suggestions on size that would be best for my motor.
    was thinking about running a Hondata S300,but not too sure.
    any help and suggestions are greatly appreciated.
    2015 F350 (work bitch)
    2011 Impreza (Daily beater)
    00 EK Hatch (Sold)
    MX73 (Sold)
    00 Acura EL (Sold)
    98 EJ6 Hatch(Sold)
    90 Civic Sedan ED3(Sold)
    91 Si Hatch (Sold)
    88 SiR-x (Sold)
    89 Rex Si (R.I.P)
    91 SiR-x (Sold)
    90 Rex Si (Sold)
    93 Ej1 Coupe (Sold)
    Feb 2009
    05 Forester X
    Talk to sentry , he's the shit
    and ue Gunna need to build pretty good forb2 bar
    Sep 2008
    Turbo stuff
    What kinda power you looking to make? 300? 400?
    And what are you looking to spend?
    Answer those and I'll give you a reply.
    Feb 2009
    05 Forester X
    knew you would post right after me
    SENTRY TO THE WIN
    Dec 2008
    Is way to loud.
    looking to make about 400hp.and as for price.looking to spend what ever i have to spend in order to have a 400hp turbo D-series.
    00 EK Hatch (Sold)
    MX73 (Sold)
    00 Acura EL (Sold)
    98 EJ6 Hatch(Sold)
    91 Si Hatch (Sold)
    88 SiR-x (Sold)
    89 Rex Si (R.I.P)
    91 SiR-x (Sold)
    90 Rex Si (Sold)
    93 Ej1 Coupe (Sold)
    Feb 2005
    Cummins F10
    400whp?
    lol
    get out your wallet
    Originally posted by Mibz
    The criteria for being a Beyond Baller is simply knowing you are one.
    Deleted F10 535d
    My hybrid burns Diesel & Oil
    Feb 2010
    CALGARY
    636, M5 clone. Ek
    Originally posted by T-Dubbs
    400whp?
    lol
    get out your wallet
    Sorry Tdubbs no wallet needed, d series isnt like those slow exspensive nazi made Audis.
    400 WHP is a very reasonable number to make on a cheap built D.
    Maybe do some fucking research before you post in here again faggit!
    Feb 2010
    CALGARY
    636, M5 clone. Ek
    Thats right i am loling at you.
    Feb 2010
    CALGARY
    636, M5 clone. Ek
    Just posted these in our dyno vault. Wanted to post these up for everyone to see
    Bisimoto 3.6 cam
    D16Z6
    Bisimoto Level 3.6 cam
    Bisimoto Valvesprings and Titanium retainers
    Portflow head
    Supertech valves
    Arias 9:1 pistons
    Bisimoto D16 spec rods
    Bisimoto prototype top mount Manifold
    Turbonetics GT-K 650
    2.5" piping
    3" downpipe + exhaust
    91 octane
    AEM EMS 1040
    18 PSI
    450whp at 293 wft/lbs of torque, with a very lopey idle
    D16Z6 head
    Bisimoto Cam Gear
    Bisimoto Pro Springs and Titanium retainers
    Bisimoto Level 3.6 camshaft
    Supertech Stainless Steel intake valves
    Supertech Inconel Exhaust valves
    Golden Eagle Head gasket
    D16Z6 engine
    Arias 9:1, 75.5mm pistons
    Golden eagle sleeves
    Bisimoto Spec H-beam steel Rods
    Honda Bearings
    Stock Ported Oil pump
    Bisimoto/Evolution Sandwich plate
    K&N Oil filter
    Bisimoto heat shielding gasket
    Golden Eagle Intake manifold
    Skunk 2 68mm throttle body
    T1 1000cc Injector dynamics squirters
    AEM Fuel rail
    AEM Fuel pressure regulator
    AEM fuel pressure gauge
    -6AN fuel lines
    Stock return lines
    AEM Water Meth kit (for super high boost!)
    Kinsler Monster Mesh fuel filter
    AEM 6040 Gen 2 EMS
    AEM UEGO
    AEM Twin fire
    AEM COP EPM
    AEM pencil Coils
    AEM Serial Gauge (this is so sick!)
    AEM boost control solenoid
    AEM 5 bar map sensor
    MSD digital Boost-a-pump pn 2351
    Power XS S680 Battery
    Rywire mil-spec wiring
    Bisimoto-Turbonetics BTX6565
    Bisimoto Prototype top mount twin scroll manifold, ceramic coated
    Turbonetics RG-45 wastegate
    Turbonetics Godzilla BOV
    3" Intercooler piping
    Turbonetics/Spearco 5-364 (3.5"x10.5"x28" wide..and yes, we made it fit!)
    -3an oil feed line
    -10an oil return
    Burns Stainless 3.5" 2-stage muffler
    3.5" aluminum exhaust system
    708whp and 487 ft/lbs on 91 octane + 50/50% water methanol
    724 and 500 ft/lbs on Torco 100 octane + 50/50% water methanol
    __________________
    517 pages of turbo d setups
    http://www.honda-tech.com/showthread...light=d16+dyno
    Nov 2004
    In Transit
    2015 MK7 GTI
    Any turbo motor making 400whp when it wasn't designed to do so is going to be fairly expensive.
    The fuel setup is going to be fairly expensive and so will the turbo, manifold and downpipe setup.
    Rods and pistons aren't usually a ton of money.
    You might be able to get away with some i beam rods and vitaras but that is pushing it at that level.
    I would expect to spend between 2-3k in a motor build unless you buy cheap parts and can assemble it yourself.
    The turbo setup will run you another 4-5k and probably another 1.5K for fuel management and tuning.
    If that makes sense to you, I would look at full-race, peakboost and possible evans tuning.
    They all have very good turbo kits that can make that power.
    As far as the engine build, I used Precise and though they looked like they did a good job, I have been underwhelmed with the overall power produced on my build as well as the oil consumption I was not expecting from a brand new motor that was broken in properly.
    Sep 2008
    Turbo stuff
    It'd probably be 4-5 grand in total.
    FJ bottom end kit $600
    ARP headstuds $100
    Delta 272 or Colt Tri-flow cam $250
    Supertech springs and retainers $300
    GM 3bar MAP sensor $70
    socketed P28 $100
    ebay intercooler, charge pipe kit, and BOV $300
    Autoworks manifold/dump/downpipe $600
    Tial wastegate $240
    T3 50 trim $600
    Autoworks oil line kit $100
    Injector Dynamics or Precise 1000cc injectors $400
    Walbro 255lph fuel pump $100
    LSD or Competition 6 puck sprung clutch $300
    Dyno tuning $300-450
    Exoect to spend another couple hundred bucks on other random bullshit, trips to the hardware store, etc.
    Sep 2008
    Turbo stuff
    Also if you can find a good deal on used parts I advise you buy em. You can save some real dough. I got an alright price on the turbo, injectors, block, and parts pile, and I gotta say a killer deal on the head.
    Here's what I spent on my current build, looking to make 300+ on it.
    Code:
    Bought:
    GT2860RS		700
    Silicone reducer	 30
    Walbro 255lph LP	120
    Block adapter		 50
    Oil line kit		100
    -3AN Restrictor		 20
    Denso 720cc		200
    Competition Clutch	330
    FJ Superkit		650
    ARP Headstuds		120
    Xenocron Basemap	 40
    Magnetic Drain Plugs	 30
    (8) NGK BKR7ES-11	 30
    Cast Mani		160
    Fresh A6 and parts	300
    Built D15B Head		440
    Hardware		30
    Sold:
    Old turbo		400
    Oil pump		 30
    To buy:
    Downpipe		300
    Dyno Tuning 		300
    Bear in mind the block I got had bores that were in spec and a crank that was in spec, so I opted against having any machine work done. If the block you choose for you build is worn excessively you might have to spend a couple hundred bucks at Precise.
    missy
    -1 for Precise in my books... between your motor, and 2 other $7500+ builds i personally know of... I have seen things from;
    -super excessive crankcase pressure
    - blowing out seals
    - stripped ATi damper and crankshaft keyway
    - a broken timing belt, followed by a built Supertech valvetrain (built by them grenading itself)
    - The Supertech head was rebuilt by them with ferrera valves - broke another timing belt
    -a 12:1 compression 2.3L (ish), fully built, LS VTEC - portmatched head / mani - skunk2 valvetrain/retainers/springs + bc stage3 cams... making only 145whp and losing power after 7400rpm...
    ... there are a few other horror stories, mabey they just don't like Hondas lol...
    ^^ just some fyi for you if you are looking to get a shop to build the motor... With a d-series, a $10000 dollar budget would be fairly suffiecient number, judging you want to drive the car around and not just down the track...
    CNC Guru*
    Instagram: goreski_rdd
    Feb 2005
    Cummins F10
    400whp?
    lol
    get out your wallet
    i guess, for some reason you think builds are free?
    Deleted F10 535d
    Dec 2008
    Is way to loud.
    Shit,thanks a bunch guys.you all have helped ALOT more than i was expecting in the first place.As for this build...it is going to be a hell of a lot cheaper than i originaly thought.
    i'll post up some pics of parts and the build process when it's that time.
    Thanks Beyond.
    00 EK Hatch (Sold)
    MX73 (Sold)
    00 Acura EL (Sold)
    98 EJ6 Hatch(Sold)
    91 Si Hatch (Sold)
    88 SiR-x (Sold)
    89 Rex Si (R.I.P)
    91 SiR-x (Sold)
    90 Rex Si (Sold)
    93 Ej1 Coupe (Sold)
    Aug 2008
    USE20
    Its one thing to make 400 "cheap" whp and its another to make
    400 "reliable" whp.
    Just remember when building..... Cheap shit ain't good and good shit ain't cheap.
    This is where I had my bottom end done. Ive heard ZERO negative feedback from them.
    I'll see how mine holds up soon!
    http://laskeyracing.com/shop/dseries.htm
    Sep 2008
    Turbo stuff
    Except the Vitara pistons and FJ rods ARE good.
    They've been taken to 600whp/mid 9 second passes at 150+ mph with stock 75mm bore and stock sleeves.
    So for 99% of turbo D series builds? They'll suffice.
    Dec 2008
    Is way to loud.
    400 "reliable" whp.
    their is no way that you are making a reliable 400+WHP civic.
    pushing 400+ is just asking for problems.
    00 EK Hatch (Sold)
    MX73 (Sold)
    00 Acura EL (Sold)
    98 EJ6 Hatch(Sold)
    91 Si Hatch (Sold)
    88 SiR-x (Sold)
    89 Rex Si (R.I.P)
    91 SiR-x (Sold)
    90 Rex Si (Sold)
    93 Ej1 Coupe (Sold)
    Dec 2008
    Is way to loud.
    Another question.
    Which turbo to buy.I can't find any so far that are good for 28 PSI boost. the most i am finding in Turbonetics are 22 PSI max.
    any help?
    00 EK Hatch (Sold)
    MX73 (Sold)
    00 Acura EL (Sold)
    98 EJ6 Hatch(Sold)
    91 Si Hatch (Sold)
    88 SiR-x (Sold)
    89 Rex Si (R.I.P)
    91 SiR-x (Sold)
    90 Rex Si (Sold)
    93 Ej1 Coupe (Sold)
    missy
    The amount of boost a turbo can produce has little to do on how much hp you will make... The flow is what you are looking for...
    15lbs on a t25 will not make anywhere near the same power as a gt35 @ the same boost pressure...
    A GT35R will get you to 400whp
    CNC Guru*
  1. Replies: 87
  2. running non-vtec motor on vtec map
    By misterrick in forum Mechanical
    Latest Threads: 11-16-2009, 12:16 AM
  3. Turbo-ing a SOHC ZC NON-Vtec help/advice.
    By ..*JDM Hatch*.. in forum Forced Induction Talk
    Latest Threads: 09-12-2009, 02:30 AM
  4. turning non-vtec into vtec
    By civic4life in forum Mechanical
    Latest Threads: 09-10-2004, 10:23 AM
  5. FS:d16a6 with vtec cylinder head
    By AutodreamMarvin in forum Automotive Parts
    Latest Threads: 01-18-2004, 05:29 PM
