Old furnace vent Q's - with pics - Beyond.ca - Car Forums
Results 1 to 20 of 24
Thread: Old furnace vent Q's - with pics
    Taco
    Default Old furnace vent Q's - with pics
    I recently bought a house built in 1973. Furnace is about 10 years old. The basement is colder than it should be. I noticed the vent in the corner of the furnace room. It vents onto side of house about 3 feet from front door and onto driveway. It looks like a dryer vent on the side of my house. The bottom of the stack is not seeled off and just pouring -30 air into my furnace room. The only thing on the bottom of the stack is a bug screen.
    The new vent for the furnace now vents up through the roof.
    Is this a neccesity for fresh air to the furnace? I was thinking it was the original furnace ventilation no longer to code. I would like to seal it off so cold air isnt coming into my basement anymore.
    Thoughts?
    6.7 CUMMINS, E50 AMG
    yes thats your combustion air
    i would call atco to come do their free furnace check up and ask them when they are there
    May 2010
    Vettel's #1
    Vettel's #1
    Shouldn't the open pipe be connected directly to the furnace?
    Vettel's #1
    2011 Mustang GT
    That's what I was thinking too...
    I would also call atco about that. It seems very unnecessary. If anything, the new furnace will have it's intake and exhaust running in the same area, and connected directly. Again, double check with a pro before sealing that off.
    Beyond's Most Wanted
    Prelude aka red rice, Lincoln Aviator
    I think it neeeds to be there. My parents replaced their furnace about 5 yrs ago (house built around '86 it think) and when the guys did the furnace they put the same thing in.
    Taco
    Thanks that makes sense. I'll call enmax and see if they do any free inspections because they are my gas provider. It does seem like it should be connected to the furnace for combustion air, because my basement floor is freezing. The bottom of my hot water tank is actually very cold to the touch because of it.
    Fiesta ST
    Mine is setup like that, but only a foot from the grill of the furnace. Installed last year and inspected by the city.
    It has a much fancier end though, sort of a U shaped end that points the open section up. That seems to keep a draft out.
    Jul 2006
    FJR1300/2018 Giant Trance 3
    I had an HVAC specialist come by and check out mine, and he agreed that it wasn't necessary, so I plugged mine up and sealed it off. Made the basement WAAAAY warmer. I was also concerned so I put a CO & NG detector in the furnace room to make sure I wasn't going to get bumped off in the middle of a cold night.
    However, that being said, my house/furnace is different from yours.
    Jan 2006
    2010 Genesis coupe 2.0t
    You can only remove it if you have a new high efficiency furnace which has its own 2 or 3 inch intake and exhaust pipes.
    Dec 2002
    I have one too. Comes in right beside the furnace and dumps -30C air into the basement. Inspection sticker on it. My place is about 7-9 years old.
    It has to be there. Can't remove it and plugging it IS against code.
    Not saying don't block it, but you run some risks and you should know the risks.
    CO2 detection is a start.
    Feb 2008
    Mine is open as well and has the exit near the furnace. As far as I know it provides fresh combustion air for not only the furnace but the hot water tank as well.
    May 2010
    Vettel's #1
    Vettel's #1
    I have an older furnace and I don't have one of these pipes. Why do some people have them and others don't?
    Vettel's #1
    Feb 2011
    Calgary, AB.
    Mines like that as well and is about 2ft from the furnace. House was built in 2006.
    2020 Subaru Forester Sport
    They make a special cover that goes on the end of those, and it connects to your furnace, so that when the furnace runs it allows air through, but blocks it otherwise. Seem it on DIY network before, can't for the life of me remember the name of the device.
    Jan 2006
    looks like fresh air intake.
    Sep 2002
    BoostLand
    something green
    Unless you are will to do a complete retrofit to new appliances that are sealed combustion , get one of these:
    http://www.hoyme.com/
    And don't for the love of god seal it off, unless you want to be a newspaper headline...
    Too loud for Aspen
    Feb 2006
    +1 for the Hoyme damper. We installed one when we first moved into the hose since the basement got fricken cold due to the wide open cold air intake. Plus it was really simple to install.
    Thank you, that is the exact thing i was talking about in my post. I knew it sounded something ending with e....howie ect, tried it all in google before giving up haha
    Jul 2006
    Meh, mine's been sealed off for 2 years now. Still not in the headlines... *sigh*
  1. How to fix leaky furnace vent?
    By topmade in forum Home and Garden
    Latest Threads: 07-20-2012, 10:56 PM
  2. Roof vent question - ok to share a bathroom fan vent?
    By toastgremlin in forum Home and Garden
    Latest Threads: 06-21-2012, 01:33 PM
  3. Roofers cover furnace vent with tarp, CO buildup nearly kills resident
    By thetransporter in forum Society / Law / Current Events / Politics
    Latest Threads: 12-01-2010, 12:24 AM
  4. Furnace help!? Any Furnace techs on Beyond?
  5. FS: Coleman Furnace (25 years Old)
    By TRBOAWD in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-24-2007, 08:47 AM
