04 SRT-4 for Bonneville - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 59
Thread: 04 SRT-4 for Bonneville
    Soon to drive a 1955 Buick, then a 1929 Willys
    Default 04 SRT-4 for Bonneville
    Car is fully built and will be going for the 230 mph record for the class at Bonnevile.
    Finally got more time to work on this.
    Turbo got here a few weeks ago. Just a little guy
    Started by moving the engine around in the bay to get the manifold in behind.
    Fought a little but got it into place nicely.
    When I went to fit the turbo on, it wouldn't fit through the top, up from the bottom or any other way. I knew I needed to modify the firewall to get the turbo to fit so I thought I might as well modify it properly. I cut it out and will make a new patch recessed back to give the turbo lots of room. Brake lines will be rebent to go lower as well.
    Exhaust/Intake are not oriented the way I need it so will rotate it tomorrow. Also going to mount the air-water intercooler inside the firewall to help it stay cool.
    Made the mounts for the fuel cell and also drilled the hole for the parachute mount though the rear facia. It will be a round tube coming through mounting to a plate on the trunk floor and a removable plate on the back so the chute can be removed, a license plate installed and the hole is hidden.
    Jan 2006
    Langdon,AB
    04 Rsx-s,07 Frontier, 11 ss/rs
    Jan 2009
    South of Glenmore Trail :P
    Depends on the day
    Very cool
    AB
    16' Tacoma Offroad
    What kind of gearing is used?
    Will you change the caster for better high speed senitivity and moving?
    Very cool build and very ambitious. Best wishes, keep us update.
    Stock 1-4 gears and a higher 5th gear. With the tire size I will run and 8500 rpm, it would do 251 mph. But I am expecting it to be drag limited in the 240 range even with over 900 hp.
    Apr 2011
    Vancouver/Calgary
    '13 GT1R
    what class are you planning to run? i'll be there this year again.
    GT1R. 8.82@169
    Mission
    PS/F currently 224 mph by Cochran racing.I don't know if I will be racing there this year, just watching. Next year for sure though.
    Aug 2011
    South
    Wow! Very cool
    Sep 2006
    calgary / alberta
    VW R32 Turbo
    Rad
    Originally posted by sputnik
    Cell providers are the next Blockbuster video stores.
    Had some more time to work on it last night so I started roughing in the Air-Water Intercooler. It is going to be inside the passenger cabin due to space issues and that I think it will keep it alot cooler and the reservoir will be in the passenger seat area. The new firewall will be fabricated such that the inlet and outlet of the intercooler stick through grommeted holes.
    Jul 2006
    SRT4- TOYOTA VENZA- CIVIC SIR
    nice build karson.. how come u dont post/visit us in srt4oa??
    63_TUNERS
    Because I hate neons.
    Jul 2006
    the more u hate the more money u will spend on your neon
    63_TUNERS
    Recieved my intercooler piping and fittings. Everything fits pretty well, but I need to do a few cuts and welds on the pipe from the cold side of the IC to the intake.
    The big brown truck delivered my wastegate and the blow off valve. It will be a tight fit for both but they should fit just fine. I am debating having the dump pipe off the wastegate come directly into the downpipe right after the turbo, thoughts?
    Sep 2006
    Nice crocs, fag.
    Originally posted by Mibz
    Nice crocs, fag.
    Just cause I won't blow you anymore you have gotten all hostile.
    Sep 2006
    I've still got those dick pics.
    Gives you something to aspire to / be afraid of.
    PS: sorry for the tearage it caused. hope it healed ok so you no longer poo out ribbons.....
    Sep 2006
  1. SRT Back Under Dodge, Dart SRT, New Crossover Detailed
    By kenny in forum Automotive News
    Latest Threads: 05-06-2014, 07:54 PM
  2. SRT-4 vs SRT-4
    By waveventureboy in forum Cars, Bikes, Machines
    Latest Threads: 04-02-2006, 02:09 AM
  3. 1988 Pontiac Bonneville
    By zain123 in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 12-05-2004, 01:22 AM
  4. 1993 Bonneville SSEI
    By tyner in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 12-05-2004, 12:14 AM
  5. 1992 Pontiac Bonneville SSEI
    By moto in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 09-02-2004, 07:36 PM
