diff -u 1985.AE86 1986-87.AE86 - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: diff -u 1985.AE86 1986-87.AE86
    Feb 2004
    84 Scirocco
    Default diff -u 1985.AE86 1986-87.AE86
    So what are the differences between a 85 and the 86-87 Corolla GTS?
    Is TVIS only on 85's?
    Are any parts different?
    What's with the black small hatch
    spoiler? Is this an indication of a particular
    year? I've seen som GTS without any spoiler at all.. Is this stock or do people
    do that?
    Info!
    =p
    Jan 2003
    Rural Calgary
    ZN6, JCE10
    info? ... www.club4ag.com
    It's all in Tech Reference
    TVIS is on both
    Grill is different, the 85 hatchback came with a rear spoiler, the later ones did not. Interior's are slightly different over EACH year.
    And then there are minor mechanical differences.
    oreo cookie
    a wrx.
    Default Re: diff -u 1985.AE86 1986-87.AE86
    do that?
    Info!
    =p
    84-85 (zenki=japanese for early)
    86-87(kouki=japanese for late)
    for the usdm versions, there arent many external differences. the front grill and tails are slightly different. kouki models got a nicer interior. enginewise they are the same except that the kouki engine a couple stronger engine parts here and there...there are bigger exterior differences for the jdm models.
    honestly i like usdm zenki model more, but id probably go for the kouki just for the velvety interior
    Feb 2004
    84 Scirocco
    thanks guys =p
    You rule. The line i have is on a kouki hachiroku.
    Interior isn't to big of a deal.. i would
    be interested to find out about the engine details..
    Thanks.. I'll check out cub4ag to see if i can find the differences.
    moo
    Jun 2003
    Alaska
    Model S
    hah, totally nerdy subject line :P
    oreo cookie
    a wrx.
    thanks guys =p
    moo
    hehe there isnt enough of a difference in the engine to really care
    Feb 2004
    84 Scirocco
    great.
    thanks.
    I never cool find any explicit differences on clubag in the tech section thou.
    i may be missing it.
    oreo cookie
    a wrx.
    great.
    thanks.
    here it is:
    The stock 4A-G connecting rod came in two major variations. The smaller rods were available in early 4A-Gs, while the larger versions were available on later models. The variations differ in 2mm in the big end and piston pin bore diameters. The OEM piston wrist pin diameter was available as either 18mm or 20mm. The smaller diameter pin was pressed fit into the connecting rod (not requiring clips to hold the pin in the piston). Later models floated the piston pin (requiring clips to hold the pin in the piston). The large “big end” was available as either 40mm or 42mm diameter. Ideally the larger diameter is preferred, because of its greater load carrying capacity. However it is slightly heavier.
    Feb 2004
    84 Scirocco
    Ok!.
    Awesome Jeff. Thanks =p
    So from reading that it would seem that it would be lighter,
    and not as strong, better reving? But probably such a small
    differnece that you would only notice the strength issue
    if you tried to boost two of the engines to the limit of
    the engine.
    Is it possible, during a rebuild to upgrade this? Basicly i'm asking
    if any other differences in the engine would be required for
    having longer conneting rods with the floated piston?
    oreo cookie
    a wrx.
    Ok!.
    the engine.
    i think its a small enough difference to really not care/notice. if u are gona be doing engine work at all for some serious power, u would definitely want to swap out the bluetop. boosting a stock bluetop to its limits is like 150hp hehe
    oh yea, i just remembered that the kouki models have slightly bigger axles. again, not a big deal
    ___________________________
    that damn 4age engine was offered in so many varieties..for instance I was working on my new engine today. It was the first time I really got the chance to look at it closely, I noticed that the intake manifold was different then a normal usdm one. It has all these extra plugs and no hole in the back for the egr system. Then I noticed that there were no holes in the oil pan for the oil cooler lines. I knew i bought a 7rib 4age but i have no idea what kidn of 7rib this is
    Red Deer, AB
    Feb 2004
    84 Scirocco
    ahh.. this kinda sucks.
    Perhaps i should not get this 1985.
    Seems like toyota would be pretty smart about this. Smaller axels makes for easy breakage. Are you refering to the rear drive axels?
    are there any issues with an aftermarket or OEM j-spec LSD in a 1985?
    oreo cookie
    a wrx.
    the most improtant thing ive been trying to say all along is that the differences are minor and nothing to worry about! until u start making serious power, either axle will be fine, and if u are making serious power, then u will be both snapping them, zenki or kouki.
    and as for issues with aftermarket, well when u buy the lsd u get a year specific one. kaaz, cusco, trd all offer corolla lsds in zenki and kouki so u are fine.
    so in conclusion, no zenkis dont suck and u would never ever in a million years notice a performance difference.
    Feb 2004
    84 Scirocco
    I'm not suggesting i would notice a performance difference. I'm suggesting that the toyota engineers did.
    I'm not concerned about making serious power, i'm concerned with getting a corolla worth putting money into, something that i will have for a little while, so the late models is more appealing, that's all.
    I'm not going to wander off and by a Celica GTS instead because of the minor differences (unless it was an all-track for nice price)
    Thanks for the info on the Diff.
    Where does everyone get parts for these? Is PE-T a good place in edmonton.
    Where is a good Toyota Shop for Getting Inspections Done?
    oreo cookie
    a wrx.
    i think u should be more worried about rust than anything else
    Oct 2002
    240sx, 300c, turbo TE72, FG1 Civic, Pilot
    For Toyota, go check out Silverstone Motorsports. I can't remember where it was though. It's right across the street from a Mcdonalds off of Gateway and... ahh shit. Just go look in the phone book. They've got some nice cars there too. ie. ma70 supra n/a converted to turbo, making 400+whp, tons of sw20 mr2's, a couple all-trac celicas, and a TRD widebody starlet with 4age and twin-side carb setup.
    For old-skool toyotas, or tuning toyotas in general, i'd go with these guys.
    ph: 403.248.1566
    email: [email protected]
    Supertech, Link ECU, ViPec, Nistune, Competition Clutch, Nardi, Personal, Worksbell, Seibon, VIS, Shine Auto Project, Agency Power, Status, Full-Race, Stillen, Mazworx,
    Megan Racing, Zedd Performance, Varrstoen
    Feb 2004
    84 Scirocco
    that goes without saying =p
    rust is the devil.
    I'm planning on getting it on a hoist and taking a shitload of pictures of the underboady and then under the carpet in the front and the rear.
    The car has had touch up paint on the rear fenders.. Are those weird little rust detector things that work through paint.. do they work?
    moo
    thx
    Feb 2004
    84 Scirocco
    Originally posted by brbHPR
    For Toyota, go check out Silverstone Motorsports. I can't remember where it was though. these guys.
    Cool
    I'll give them a shout.
    oreo cookie
    a wrx.
    Cool
    if u are dealing with raymond, dont expect him to even acknowledge u until u actually own a corolla haha. even when u do he will be quite rude...altho he does know a lot and does good work.
    another place u might wana check out is TT automotive.
    Feb 2004
    84 Scirocco
    mm
  1. 1985 Toyota Corolla GT-S (AE86)
    By GTS Jeff in forum Toyota / Lexus
    Latest Threads: 11-16-2008, 10:35 AM
  2. WTB: 1986-1988 Accord or 1985-1987 Prelude
    By 3G in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 11-03-2003, 05:59 PM
  3. FS:1986 Red AE86 Hatch(project car)
    By JDMAE86 in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 09-28-2003, 11:27 PM
