God I hate those strings that are both series and parallel. You still have to check 1/2 the lights on it anyways, when one goes out.This quote is hidden because you are ignoring this member. Show Quote
Finally finished this project.
And another one. We bought the house about 10 months ago, I've painted/replaced almost everything in the house. Previous home owners had 3 dogs and did not give a f$ck about their investment.
These pics are about 3 months apart.
Finally pulled the trigger on a Desert Spring humidifier.
Pain in the ass to install in the limited space. Cold air return is right against the wall, and my shelves/electronics workbench are pretty close as well. Existing hole was bigger than needed too.
Can't believe how simple it is for the price, no heat/air sensor, so the motor runs constantly as long as the humidistat calls for humidity, even if the furnace isn't on. My furnace control board doesn't have a switched 24vac out, but does have a switched 120v so will be installing a relay to remedy that.
Keep us updated on the change in humidity.
Are those turds in the top photo? Man, that is nasty.This quote is hidden because you are ignoring this member. Show Quote
Plugs from aeration would be my guess lol.
Last night I took down the light fixtures in the kitchen and installed some of the low profile LED pot lights... So much better!!!
Not sure if serious.This quote is hidden because you are ignoring this member. Show Quote
Pretty sure he aerated his lawn...This quote is hidden because you are ignoring this member. Show Quote
Haha, it wasn't serious. Definitely assumed it's aeration (95% sure), but it would be funny from the dog comments if there is a small chance it was actually poo.This quote is hidden because you are ignoring this member. Show Quote
LOL! They are plugs, but previous owner did leave us with about that same amount of dog shit hidden under the snow.
Not my house bit I'm changing a brown kitchen to a white kitchen. Basically remove all brown colored stuff, pull the old edge tape off of the cabinets, glue new edge tape on and trim it and then install all the white replacement parts. Builder's design person forgot to inform cabinet, tile and flooring companies of colorchanges from original design. $20-30,000 booboo in two houses.
Will fuck off, again.
what type of edge tape do you use? I would like to replace mine
Some plastic stuff that the company I subcontract to provided - came off of their edge banding machine. Using an aerosol contact cement, not a difficult job - just very tedious.
Has gone from 21 to 30% in about 4 days.This quote is hidden because you are ignoring this member. Show Quote
FastCap is awesome, built in adhesive and strong as hell. You can pick it up a RicheleuiThis quote is hidden because you are ignoring this member. Show Quote
Richelieu is an evil, evil place. Kind of like KMS tools and to a lesser extent, Lee Valley Tools.This quote is hidden because you are ignoring this member. Show Quote
Changed the fuses on a string of Christmas lights.
Switched front door from black to blue.
