what did you do around the house today? - Page 55 - Beyond.ca - Car Forums
Page 55 of 158 FirstFirst ... 45 54 55 56 65 ... LastLast
Results 1,081 to 1,100 of 3145
Thread: what did you do around the house today?
  1. #1081
    Oct 2007
    YEG
    Lotus and a Honda.
    Quote Originally Posted by SkiBum5.0 View Post
    Go slow with the acid, and have the wind at your back. For that size tub, I’d start with a cup, or 250ml
    Serious?? I'm reading like 3 teaspoons from poolcalculater.com.... tub is only 125g
    Cereal Killer.
    @iambrianspilner
  2. #1082
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by sikid111 View Post
    125 GRAM tub?! Is this a tub for ants?!
    But seriously... when I first got a tub I used a LOT of test strips... you will go mad. I don’t even measure things now, a splash of this, a dash of that... slight burn of chlorine n the nostrils and off you go
  3. #1083
    Aug 2012
    Down by the River
    GMC Sierra, LX570
    I was guessing the volume of the tub. But thinking about our pool dose in TX, a couple teaspoons does make sense
  4. #1084
    Oct 2007
    YEG
    Lotus and a Honda.
    Quote Originally Posted by ercchry View Post
    I read that using Derek zoolander voice haha.
    Once I get the first round done and get used to it a bit I'll be splashing and dashing the rest of the way.
    - - - Updated - - -
    Yea 2 person, 125 gallon. Not big at all. Just threw in 3 teaspoons, ph was at 9.0. Hopefully they will correct ph and alk, will know in a hour.
    Cereal Killer.
    @iambrianspilner
  5. #1085
    Aug 2012
    Down by the River
    GMC Sierra, LX570
    Can you find the drop test kits? Much more reliable.
  6. #1086
    calgary ab
    4x4
    pH of 9 is pretty wild - Calgary tap water last I checked is running around 8.2
    Sure you're not adding pH up rather than down?
  7. #1087
    Oct 2007
    YEG
    Lotus and a Honda.
    I'll look into this, but I'm using my blue lab PH pen now so alot more accurate then a color lol.
    - - - Updated - - -
    Quote Originally Posted by AndyL View Post
    I got 9 from the test strips but my meter said dif. Right out of the tap. It's been a bit high the last few months..
    - - - Updated - - -
    The acid did the trick! Dropped and levels are a hell of a lot better. When I googled my issue it seemed like a few people have ran into it, and then switched to acid and it solved it.
    130g of ph down over 2 days, and it didn't move once. 3 teaspoons of the acid and down to 7.2 in an hour.
    Cereal Killer.
    @iambrianspilner
  8. #1088
    Apr 2004
    - - - Updated - - -
    - - - Updated - - -
    i have the same pen. You get it from incredigrow? How often do you calibrate it?
  9. #1089
    Oct 2007
    YEG
    Lotus and a Honda.
    Hydro-lite in Edmonton. I usually calibrate every 2-3 months depending on how much I use it. Not sure how I feel about using it in the hot tub and then the hydroponics...
    Cereal Killer.
    @iambrianspilner
  10. #1090
    Feb 2006
    CEF4
    Ralli Machine
    OK maybe I should start a new thread, but I've seen advice here. I need some help with the doors on my house. Specifically the exterior doors. It is strange, it is almost like the trim or the door are 1/8th of an inch out. They've always been that way but now that I'm on week 3 of being at home, it is really getting to me.
    I've tried adjusting them with ever known 'trick' in the book. Resetting the hinges, bending the hinges, even getting some weather stripping and stuffing it in there. They just don't seem right. Is there a way to move the door closer to the deadbolt side? It isn't out of square, I've checked that. It swings fine. I just get leaks.
    Cos...
  11. #1091
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Got another 20 birdhouses cut, sanded, and packaged up. Delivering them to the kids in the neighborhood tonight.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
  12. #1092
    calgary AB
    toyota MR2
    This was the best video I’ve seen for hinge shimming
  13. #1093
    Fiesta ST
    Quote Originally Posted by The Cosworth View Post
    You could put flat 1/16” shins behind the hinges on both the frame and the door. Should shift it over.
  14. #1094
    Feb 2006
    CEF4
    Ralli Machine
    Quote Originally Posted by blitz View Post
    Quote Originally Posted by thinmyster View Post
    I feel stupid I didn't think about this before. Thanks
    Cos...
  15. #1095
    Stampede Central
    is pretty sharp lookin'
    Gonna try and get through this list for Apr
    So far Day 1 seems to be just moving things into a pile elsewhere
  16. #1096
    calgary ab
    4x4
    Figure it's worth asking here...
    Looking for local sources - more on affordable side not baller side.
    Tslot extrusion in 6'+ lengths 10 series imperial or 20 series metric.
    And does anyone know of a sign shop that might have hunks of ACP/alucobond they sell from the scrap pile?
  17. #1097
    Changing light bulbs that cost me $8 a few years ago and should have lasted a decade.
    Le irritating.
  18. #1098
    Cleaned the tube thingy under my daughter's sink. Hair and other assorted filth was preventing proper drainage.
    Attachment 90063
    Attachment 90064
    Attachment 90065
    Had to take the sink stopper thingy and reassemble. Must have been backwards. But it works good now.
  19. #1099
    Le irritating.
    Yet another way China has effed everyone.
  20. #1100
    Cochrane, AB
    Trucks
    Poked my finger through the basement ceiling drywall. Bathtub drain failed while my kid was soaking in the tub. Good times all around.
  1. What did you do to your car today?
    By 6Speeder in forum General Car/Bike Talk
    Latest Threads: 01-09-2018, 09:39 PM
  2. What did you do to your FoST/FiST/Fusion today?
    By RedApe in forum Ford ST Owners Club
    Latest Threads: 06-21-2015, 09:33 PM
  3. What Electronics did you buy 10 years ago ? and which do you still use today?
    By thetransporter in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-01-2012, 07:45 PM
  4. Did you have turkey today?
    By Awd-Tsi in forum General
    Latest Threads: 10-11-2010, 04:49 PM
  5. Replies: 27
    Latest Threads: 11-13-2004, 05:25 PM
