Re: Shaw throttling internet upload to another shaw customer? (5 megabits up)
Originally posted by thetransporter
At work we have a shaw 5 up/100mb business package
at home i have the 25 megabit/2.5 up
with no load on either ends (and no routers on each) when I do a FTP transfer from the server they jump to 640 kiloBYTES (5.1mbits) a second in the first 20 seconds and then go down to 270-500
i tried http as well.
when we had the 2.5 up, and the 1mb up, it would max out on all transfers
in 2009, shaw said oh our network is not yet ready so that is normal (we were paying $300/month for the 5/5) connection than that changed to 50 down/5 up and to about 100$/month
this is the server speedtest
Tech support sent someone out, he didnt know anything about ftp. said everything is working as it should, the speed issues I have to contact shaw for them to "review"
what would you guys suggest or know and care to share?
*business modem is in bridge mode
*tired binary files and text files
Interesting...
I'm on Shaw Biz 100+. Whenever I'm uploading I can max out and keep my upload maxed. I'll be pushing an update to clients and my upload will be 600+KB/sec constant for however long it takes (sometimes an hour or two)...
I would say that 500KB/sec or anything above is acceptable. Anything less and it could mean a number of things.
Consider that there might be a heavy load on the network (either on your work end, or in your area as a consumer). Is there anything else running hosting on either end? If the server is hosting other stuff and other people are snatching stuff off it, that might be why you got high speeds then had it change.
Is it standard FTP you're using? Or SFTP? If you using secure FTP it could have to do with on-the-fly encryption...
Sig was pwned by Moderator!
