It was odd as she did move the barriers about 5-6 feet.
Will fuck off, again.
Half the time the issue is with cheap SD cards as well. We have several 40$ units and they all work (and play back) fine.This quote is hidden because you are ignoring this member. Show Quote
Yea CL10 would be my bare minimum recommendation.... but I've switched to U3 so that I can have commonality with all my devices.This quote is hidden because you are ignoring this member. Show Quote
This.This quote is hidden because you are ignoring this member. Show Quote
Make sure you use a SD card with a high write speed. It makes the difference.
Are you not the one at fault here? That or there should only be one turn lane with the work that is going on. Your turn lane ends in a dead end, hers does not
- - - Updated - - -
Are you not the one at fault here? That or there should only be one turn lane with the work that is going on. Your turn lane ends in a dead end, hers does notThis quote is hidden because you are ignoring this member. Show Quote
_____ASP______
current ski quiver:
park,all mtn: 181 Armada AR7
big mtn, pow: 185 Armada JJ
Looks like 2 lanes to me based on the markings. It only looks like a single lane if you follow the dark patch of pavement, which is what's confusing shitty drivers.This quote is hidden because you are ignoring this member. Show Quote
I think you are right. Quite a sketchy dual lane turn since I don't even see a warning for 'right lane ends ahead'.This quote is hidden because you are ignoring this member. Show Quote
It's definitely 2 lanes there, that lane doesn't end. Lines just aren't marked very well.
I had a mattress and boxspring come flying at me on the I5 outside of Seattle.. Wish my dash cam had arrived in time so I could have had footage of that fiasco..
2 chicks trying to figure out what to do.
There is definitely 2 lanes there and the lane doesn't end . As you can see we both exited afterwards and clearly there were still two lanes going straight through. As Rage2 stated the markings are there and very faint as it's the temporary lines.
Stupidity is a disease we all have, it's like a form of brain herpes. Outbreaks will occasionally occur.
Finally had time to compile all the summers adventures.
Saw this today on the way back from the junkyard. Couldn't tell if the van was missing the tire or the whole wheel, but he just kept going..
dv/dt
Not my vid but this looks like Mackenzie/Prestwick.
https://vid.me/JP5nH
wrong side of the road, on the sidewalk, crash in the dirt. running from police. might be best video yet.This quote is hidden because you are ignoring this member. Show Quote
That’s from 2015 and yes it’s pretwick, if he had made a turn instead of going straight in one of the intersections he would have passed my house
I’m actually really surprised the police kept up with him like they did
Why do they always run
Special kind of stupid that guy...
