Garage lighting - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Garage lighting
    Bunch of Honda's
    Default Garage lighting
    Moving in just over a week and have a bare detached garage (20'x22') to finish. Currently the garage has two light bulbs and the o/h door light. Needless to say that's not going to be sufficient, I want bright.
    Went to Home Depot and Lowes to find some fluorescent lights and nobody stocks anything with a reflective guard on them (which is what I currently have). They're all either bare bulbs or the enclosed fixtures with diffusers.
    If I slap up 4 or 5 of these fixtures is it going to be bright?
    http://www.homedepot.ca/product/96-i...m-light/972616
    Any other suggestions on lighting or things you wish you did differently?
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    Depends how bright you want it... I originally put in 4x4 bulb T8 fixtures in my 24x26 garage and even though it was reasonably bright, I still had some shadows against the walls/corners so I added 4 more (or 32 t8 bulbs in total). Depending on how much time you plan on spending in the garage, I'd definitely suggest going "too bright" than not bright enough.
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    I have a 18x24 attached garage, in there I have 4 2x4ft T8 fluorescent fixtures and I find it is generally bright enough. Obviously if you're under the hood or under a car it isn't enough but that is what trouble lights are for. When I'm running wood through table saws or building shit in my garage it is plenty bright.
    I find even though the T8s will start right down to -20*C they are pretty dim until they have run for 10-15 minutes.
    Rona has some fixtures that have a white "reflective" guard behind the bulbs. It does a little better than just the bare bulbs. I have both types in my garage and I do find them a little brighter directly underneath the fixture.
    For 20x22 I would be on the fence between 4 fixtures and 6, I guess it just depends on how bright you want it. Maybe put up 4 then add 2 more if you find you need it? They are only $20/each + bulbs (or about $24-25/fixture with bulbs) so they aren't too expensive and it isn't hard to add more
    Nov 2011
    My garage is a dark zone, I have yet to be in a residential garage where someone said, "It is too bright in here". I might look at these LED tubes in the future. I do need to do something though, perhaps a local dealer has them:
    http://www.ledlightsworld.com/led-fl...ubes-c-51.html
    Aug 2009
    Local
    Can't driver because I'm legally blind
    May 2004
    Calgary, AB -- Canada
    Yup, Rona carries the ones you want:
    http://www.rona.ca/en/shoplight-fluorescent-fixture
    http://www.rona.ca/en/fixture---48-i...escent-fixture
    http://www.rona.ca/en/48-in-fluorescent-fixture
    http://www.rona.ca/en/fluorescent---...escent-fixture
    http://www.rona.ca/en/fluorescent---...e-11005191--1#
    http://www.rona.ca/en/fixture---96-i...scent-fixture#
    http://www.rona.ca/en/industrial-flu...-fixture-96-in
    Also a lighting supply store, such as Sav-On Electrical in Calgary, will have more options:
    http://www.savonelectrical.com/
    May 2004
    FAT tires
    i have 9 2x4ft t8 fixtures evenly spaced and it is generally pretty good in a 22x22, but still ended up adding 2 more more hanging above the work bench. if i were to do it again I'd go 12 fixtures, 4 rows of fixtures running front to back + the hanging ones over the work bench.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Does anyone know if these (the ones pictured above) also put out heat. Reason is I left those style of lights on in my garage overnight last night and my garage was pretty warm this morning, the only other thing I can think of is that the light switch is also connected to some sort of heating device in the garage.
    Quote Originally Posted by BavarianBeast View Post
    Could have been over 60% if I wasn’t a paper hand bitch
    Aug 2009
    Local
    the bulb probably gets to about 30 but the internals could reach higher temps, if you left them on i could see it warming up a garage if there wasent to much heat loss.
    thinking about it those 4ft bulbs come in a 40watt and 30watt maybe one make more lumen over the other.
    EDIT: Looking at thermal pictures and knowing the limitations of thermal imaging
    Dec 2004
    1917 Model T, VW Baja, '18 Ram 2500 CTD/6spd
    I'm going with 8-10 4ft 2 bulb T8 flourescent fixtures in the center of my 24x26, then adding whatever lights are needed around the edges for workbenches / task lighting etc.
    I don't think 4 x 4ft 2 bulb T8 fixtures will be enough in a 20x22, but I guess it depends if you're using your garage for parking or wrenching. I'll be using mine solely for wrenching, and doing some paint/body so I want to err on the side of 'too much' light.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    Hmm my garage must be more insulated than I thought it was because it was -7 outside last night in our area.
    Nov 2012
    West Bengal
    Smile
    My friend has a 15 x 15 garage and has 4 light tubes. That 4 tubes bring the garage more than enough light which is very bright that hurts the eyes. So, I would recommend you using about 3-4 light[BRIGHT ONES]. I guess that it would be sufficient.
    calgary ab
    4x4
    Honestly, if your going with flourescents, spend the extra 10$ and get T5's - less wattage more lumens, and your pretty much guaranteed to get electronic ballasts not the old transformer/tar ballasts...
    High output T5s are even better - but they come with a price...
    Mar 2009
    Old thread bump..
    Who has the best deal on T8 fixtures locally in Calgary? The electrical supply places might have a better price than the big box stores?
    Just trying to save driving all over.. $50/fixture is kinda nuts for a 2 tube 4' T8 fixture.
    Cheers
    TimG
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    I paid ~$20/fixture for dual-tube 4 foot T8 fixtures. Rona / Home Depot usually have one on for around this price (between $19 and $22) that will have an electronic ballast. If you want something other than a shop light, with a plastic lens on the front or that is decorative you'll pay around $50/fixture
    2020 Subaru Forester Sport
    My fixtures came from Home Depot and were like $20, and did come with a plastic lens on the front, so there are options out there with the lens. I have 8 in my garage. Lights up like daytime anytime I use em.
    Only 15min from Aspen!
    Nothing interesting anymore
    I paid the same, bought 9 of them for my garage, however the plastic light diffusers all fell down and broke after one winter, lol. Not that it made much difference to the lighting anyways.
    Bunch of Honda's
    I used the same ones
    http://www.homedepot.ca/product/4-t8...paround/908105
    I ended up putting in 4 of these and it's pretty damn bright haha. Put two at the front end of the cars above work bench running side to side and then one above each car running front to back. Its not as bright at the back ends of the cars but we leave them parked so close to the o/h door we can't work back there anyways.
    Yep those are the ones.
    I had mine for two winters now, no problems with the lenses, been up there the whole time, so not sure why all of yours fell out. I got 8 and still have all the lenses
    I bought them all at once, maybe I just had a bad batch or something. The plastic was just too short, and a slight expansion/contraction of the metal sides seemed to doom them to falling and breaking into pieces on the ground.
  1. Opinions on garage lighting.
    By 03ozwhip in forum Home and Garden
    Latest Threads: 04-08-2020, 10:01 PM
  2. Speeding car hits tree and first garage, comes to rest in second garage
    By Markham in forum Society / Law / Current Events / Politics
    Latest Threads: 07-18-2011, 03:05 PM
  3. Garage doors - if you're still planning that garage...
    By AndyL in forum Home and Garden
    Latest Threads: 11-02-2010, 10:02 PM
  4. Garage lighting
    By Cooked Rice in forum General Car/Bike Talk
    Latest Threads: 12-14-2008, 12:51 AM
  5. One Car Garage vs. Two Car Garage
    By fordo_11 in forum Real Estate / Finance
    Latest Threads: 07-11-2006, 11:52 AM
