Project Midlife crisis - Page 5 - Beyond.ca - Car Forums
Page 5 of 5 FirstFirst ... 4 5
Results 81 to 93 of 93
Thread: Project Midlife crisis
  1. #81
    Sep 2002
    BoostLand
    something green
Size:  302.1 KBName:  IMG_20220418_1940351.jpg
Size:  132.8 KBName:  IMG_20220424_1514500.jpg
Size:  314.2 KBName:  IMG_20220424_1617313.jpg
Size:  267.1 KBName:  IMG_20220424_1617313.jpg
    Too loud for Aspen
  2. #82
    Cochrane, AB
    Trucks
    Quote Originally Posted by Maxt View Post
    I started on the exhaust finally. I bought the cold cut metal saw which really made cutting stainless tubing a super easy task.
    The headers terminate on a really bad angle on the outside of the frame rails, so I had to do some custom radius pie cut pieces to correct the plane of the exhaust, and fit the big muffers in there. I chose dynomax 3.5" mufflers in stainless, basically only thing I could find in stock. I am not sure how loud it will be, but i'm guessing it will probably set off it's fair share of car alarms.
    Better quiet it down with a couple of turbos before the neighbours get mad at you.
  3. #83
    Sep 2002
    BoostLand
    something green
    I thought about doing something like that, then decided I would have a tough time cutting up my rad support for an intercooler.
    I have a 2wd 85 dodge sitting here, I may do a twin turbo gen 3 hemi build on that one at some point since Holley is making all the parts to do that swap now.
    Too loud for Aspen
  4. #84
    Sep 2002
    BoostLand
    something green
Size:  208.2 KBName:  IMG_20220430_1541082.jpg
    Made the downturn tail pipes.
    Too loud for Aspen
  5. #85
    Mar 2007
    Edmonton area
    Has wheels
    That's some very acceptable welding right there
  6. #86
    Sep 2002
    BoostLand
    something green
    Tacked together, one last marathon of welding to do.
    Too loud for Aspen
  7. #87
    missy
    Killer work right here, master manual man for sure
    CNC Guru*
    Instagram: goreski_rdd
  8. #88
    Sep 2002
    BoostLand
    something green
    Test fit, need to add some leafs and the body lift.
    Too loud for Aspen
  9. #89
    Sep 2002
    BoostLand
    something green
    Truck is home for now. I had to buy springs with 2" more arc to level out, the front springs seem to be way stiffer than the rears, even the engine weight didn't drop the front. I also moved the rear axle and inch rearward to center it more in the wheel well. The urethane body mount kit wasn't in right, I redid it and the truck gained an 1" of height over and above the spring change. Next is get the engine fitment finalized.
    Too loud for Aspen
  10. #90
    Sep 2002
    BoostLand
    something green
    Made it to the dyno.
    Too loud for Aspen
  11. #91
    Cochrane, AB
    Trucks
    What's the engine again? 505 ci? Great torque across the board, what's it do lower than 3300 rpm or is that the converter stall speed?
  12. #92
    Jan 2017
    Summer car or work truck
    You still have a BlackBerry! I'm jealous. I miss mine every day. Also BlackBerry Hub. Still using that on Android, but it's not working well with both my emails.....
    Looks like good power there too!
  13. #93
    Sep 2002
    BoostLand
    something green
    Yeah, 505. It was difficult to load it lower than that, that seemed to be where the dyno would flash to. I'm not sure how the converter choice is going to work out now, it's making about more torque at a lower rpm than was anticipated. When I ran the numbers before, I calculated 620 ftlbs and torque peak of 5000 rpm.
    - - - Updated - - -
    I have such hard time with callused hands and touch screens.
    Too loud for Aspen
  1. Replies: 74
    Latest Threads: 05-17-2015, 11:48 AM
  2. Replies: 28
    Latest Threads: 01-08-2012, 11:33 PM
  3. The affordable midlife crisis car
    By t3rry in forum Cars, Bikes, Machines
    Latest Threads: 02-12-2004, 12:25 PM
  4. Ebay: Idenity Crisis, civic
    By Zephyr in forum Cars, Bikes, Machines
    Latest Threads: 07-01-2003, 07:32 PM
  5. major crisis with the accord
    By Miss_Celica in forum General Car/Bike Talk
    Latest Threads: 05-21-2003, 10:09 PM
