I put a bucket under the dripping a couple of years ago and this one bucket never got an inch of water in it at any time, it was there for years. Last week I happened to hear some splashing while I was downstairs and found the bucket entirely full to the rim, I have no idea how long it had been full as any drops splashing out onto the concrete floor would probably evaporate pretty quickly. So I emptied the bucket and now after a week it's half full again with drops every 3 seconds. I'm wondering if it'll make it through tonight.
I did mention it to my furnace guy that came and replaced my smart valve 2 years ago and he told me it was the tap that was coming out of my hot water tank pipe which was causing it. He said I should remove that entire unit from the furnace right back to the hot water boiler and put a plug type thing in there. And he gave me the plug for free. Here are some photos to show what I mean.
The furnace, hot water boiler and bucket. You can see the unit on the side of the furnace.
This is the top of the hot water tank, see the piece tapped into the pipe and the hose coming out. WTF is this? The furnace guy tried turning the t-bar handle to loosen it but broke it off, you can see it sitting there below it (gold piece). So he gave me a new plug piece to put in there and left.
He said I had to shut off the water, turn it with pliers a little bit to alleviate all the water pressure, then take it out all the way and put the plug in there.
The unit causing the dripping.
The screw on the bottom right which is where all the water is leaking out from.
So now that I've forgotten his instructions completely and have had no luck finding this plug piece he gave me which is somewhere in my house, can someone here re-explain to me how to get this box off so the leak stops? Thanks a lot.
