Shane Homes standard furnace is the Carrier 59sc2 and I was asked if we wanted to upgrade. Not knowing too much about this brand and model, those that do have the standard furnace how do you find it, does it heat your home well, quiet, etc? The upgrade is the Carrier 59TN6. The biggest differences between the two is the upgrade is 96% efficiency and has 2 stages for heat delivery whereas the standard is 92% efficiency and has only 1 stage for heat delivery. I am not sure if the upgrade is worth the $2700 upgrade so I am curious if I can get away with the standard. Thanks
