^ yeah this or sand/file a 9/16 to the thickness you need is your best and cheapest bet. The latter would be the easiest, as i have no idea who in calgary would have that exact size of hex bar stock. Even so after you cut it, it'll likely still need to be filled somewhat to the exact thickness you need, as cutting each one to the 12 mill's each time will be next to impossible if doing it by hand repeatedly which you obviously will be.
I'd recommend using a caliper to make sure both sides of the nut are the desired thickness while your sanding or filing it down. At least that way you'll know if you have any high spots. As you file it down, you'll probably create burrs within the ends of the thread profile. So you may want to have a tap handy if you have one in that size. Otherwise I'd recommend threading the nut (about 3-4/5th the way) onto the end of a bolt, then as you think you're finished with sanding or filing one side of the nut down, thread it down the bolt. Doing that will use the bolt threads to clean out any burrs or sharp edges, thus making installing it on the desired bolt a lot easier. It'll also help you hold the nut in place while you sand or file it, but you may want to double nut the end so it's locked and doesn't move at all while you're working on it.
